2 questions about b16a2 in eg
Old Aug 2, 2008 | 07:04 AM
hondazccivic's Avatar
Default 2 questions about b16a2 in eg
I have a 92 civic hatch with a b16a2, I orderd some poly urethane mounts, 2 of them fit (the rear, and the tranny mount). The driverside engine mount that goes right by the timing belt cover does not. It has 3 holes to be bolted in, and my original mount (stock) only has 2, any idea what I have to do to fix this?
Also will the 92-95 civic stock shifter linkage work? As I believe mine is belt, as it keeps popping out of the bushing located right under the shifter console, (not at the tranny). Let me know guys asap, want this **** to get fixed, thanks.
Old Aug 2, 2008 | 07:18 AM
superfast666's Avatar
Default Re: 2 questions about b16a2 in eg (hondazccivic)
yeah you bought integra mounts if your going to use them you need 94-00 integra post mount
Old Aug 2, 2008 | 07:23 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondazccivic &raquo;</TD></TR><TR><TD CLASS="quote">
Also will the 92-95 civic stock shifter linkage work?</TD></TR></TABLE>
No, D-series linkage won't work. Get B-series linkage (except Del Sol).
Old Aug 4, 2008 | 06:09 PM
Default Re: 2 questions about b16a2 in eg (mcvtec)
so pretty much 94-01 teg linkage? or will prior to 94 teg linkages work aswell?
Old Aug 4, 2008 | 07:50 PM
yes 93 integra linkage will work
anzh86
Jul 22, 2010 01:50 PM
dem0nk1d
Feb 7, 2006 12:50 PM
94si94cx
Jan 1, 2004 03:00 PM
romeirome1
Dec 16, 2003 05:56 PM
redlineintegra
Mar 31, 2002 06:22 PM
