92-95 Civic d-block mounts to b-sers.
Well the 92-95 D-sers mounts adapt to the B-sers? I know the bottom block mounts bolt up fine? I have a Ls sitting in the garage waitting for a drive side mount, and wondering if it will except the driver side D-mount.
Re: 92-95 Civic d-block mounts to b-sers. (dem0nk1d)
you just need the mount by the timing belt cover from the same year integra. another way to do it is keep d series mount and use a delsol dohc vtec engine bracket it will bolt up to d series chasis mount... Oh.... you will also need integra trans mount bracket that is under by the firewall.. and shift linkage of course...
thanks guys that clears up alot of info. also I can just use all the mounts off of hte intregra if wanted... instead of using hte civic rear and tranny mount.
doggworld1233
02-23-2010 07:39 PM
80 dolla crx hf
11-14-2008 09:58 PM
