Okay IACV..,.,.,.,.,.,.
Old Aug 1, 2008 | 05:24 PM
Spool This's Avatar
Default Okay IACV..,.,.,.,.,.,.
so i have a problem with the IACV, it seems in the mornings it doesnt want to idle always wants to die. but after fully warming up it idles fine.
now i did change the iacv and tps....mind you both parts are used. so im think i still got a bad IACV, now my next question to you guys is.
when its warmed up(drivable) it doesnt respond well to throttle, meaning i can only use 1/4 throttle anything past that has no power and climbs like 1/4 throttle is on all the time. now i did replace my TPS and calibrated it but only got .4v-4.8v so would that make a difference or no? or is my IACV still holding back on throttle response? any help would work if not than Fu guys! j/k
Old Aug 1, 2008 | 05:54 PM
Spool This's Avatar
Default Re: Okay IACV..,.,.,.,.,.,. (Spool This)
ttttttt
Old Aug 1, 2008 | 06:00 PM
AnotherSI's Avatar
what year civic is it? if it was older it could be equipt with a fitv (fast idle thermo valve) which acts kinda like a idle air control but only used before the vehical is warmed up only.
Old Aug 2, 2008 | 09:45 AM
Spool This's Avatar
Default Re: Okay IACV..,.,.,.,.,.,. (AnotherSI)
well the body is a 94 i have a JDM D15B in it.
Old Aug 2, 2008 | 01:32 PM
Spool This's Avatar
could reversed map and tps harness plugs cause 1/4 to 1/2 throttle cut off?
Old Aug 2, 2008 | 08:20 PM
Spool This's Avatar
TTT k check harness for MAP, and TPS. both correct so i may need to replace my map sensor sinse i noticed a little ding on top of the sensor. but i need advice with a IACV or maybe fitv.
Old Aug 2, 2008 | 09:21 PM
OMGWTFBBQ!'s Avatar
I would go with cleaning your IACV, I'm not sure if the D6B has a FITV, but you can check to see if tis there, if it is, clean that too.
Old Aug 2, 2008 | 09:34 PM
Spool This's Avatar
Default Re: (OMGWTFBBQ!)
i will have to check if it does i think it does, but would that cause poor acceleration as well? is the FiTv mechanical? or elecrtrical?
Old Aug 2, 2008 | 09:36 PM
OMGWTFBBQ!'s Avatar
If your valves are throwing CELs then your car may go into limp mode, which will kill your power.
Old Aug 2, 2008 | 10:27 PM
AnotherSI's Avatar
Default Re: (Spool This)
the fit valve is purely mechanical. has a thermo spring that reacts to coolant temp and moves a plunger to allow air flow past the throttle plate to control idle when the engine is cold. not only can it be cleaned but on the back side of it there will be i believe two phillips head screws holding on a plate. if you remove the plate you can see the plunger which can be adjusted. if its turned all the way clockwise then you know the plunger is alright.
Old Aug 3, 2008 | 01:25 AM
Spool This's Avatar
my valves arent throwing a code but they do tap. wierd thing is i rarely get a code 14. when i do i have to go past a certain distance in throttle before it picks up power again. but this rarley happens. i wonder if its in limp mode but not throwing something im just not seeing.
also i will try cleaning that fitv asap. and update.
minilogoguy18
Sep 2, 2010 03:10 PM
magicguy
Jan 30, 2009 02:00 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
k_lude
Oct 2, 2006 07:25 PM
