93 civic 2dr ex no spark?
Old Aug 1, 2008 | 02:24 PM
kennyc2189's Avatar
Default 93 civic 2dr ex no spark?
like the topic says its a 93 civic 2dr ex d16z6 i replaced the timing belt due 2 water pump freezeing did leak down test 2 make sure no bent valves got it back together and it wont start so i checked for spark found none checked fuses found all good swaped dizzy out plugs and wires still no spark cheched dizzy for power and ground found ok what else can i check? o yah i was gonna try a diff ecu but this is an automatic and no 1 i know has an auto ecu its a guy from my works g/f car so i need to get it going
Old Aug 1, 2008 | 03:33 PM
Syndacate's Avatar
Default Re: 93 civic 2dr ex no spark? (kennyc2189)
Heh, check the ECU because there's not much left.
Did you change the entire distributor?
Old Aug 1, 2008 | 03:39 PM
1992Si's Avatar
Was it a known good dizzy?
Typically it's going to be your igniter or coil. With the age of the car it's good preventive maintenance to replace it with a rebuilt dizzy.
If the dizzy works in another car, it must be the ECU, IDK
Old Aug 1, 2008 | 03:40 PM
kennyc2189's Avatar
Default Re: 93 civic 2dr ex no spark? (Syndacate)
I CHANGED THE ENTIRE DIZZY i opened the ecu up on both sides and inspected for burt connections but found none
Old Aug 1, 2008 | 03:41 PM
kennyc2189's Avatar
ya it was a known good dizzy but it was off a d15 out of an eg hatch just used vice grips to hold it in place since the bolt holes r diff but it still should have made spark
Old Aug 1, 2008 | 03:42 PM
Syndacate's Avatar
So there's power to the dizzy plug, but no spark?
Most likely means the problem is a ground or the dizzy, but you said you changed the entire dizzy, so I don't know.
Old Aug 1, 2008 | 03:43 PM
kennyc2189's Avatar
yah good power and ground i even used my power probe to apply power and ground at the same time directly still no spark
Old Aug 1, 2008 | 03:48 PM
1992Si's Avatar
It's along shot but did you clean the ECU ground on the thermostat housing ?
Old Aug 1, 2008 | 03:53 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kennyc2189 &raquo;</TD></TR><TR><TD CLASS="quote">yah good power and ground i even used my power probe to apply power and ground at the same time directly still no spark </TD></TR></TABLE>
If you gave power to the distributor from an external (not harness) source, and when you cranked it it still didn't spark, then it's a problem in the dizzy, most likely the igniter if you're not getting any spark at all.
Old Aug 1, 2008 | 04:35 PM
kennyc2189's Avatar
i just tapped into the harness and added power and ground and i tryed it on both dizzys no didnt try cleaning the ground i just checked it made sure it was tight
Old Aug 1, 2008 | 04:41 PM
kennyc2189's Avatar
ne1 else have ne ideas i will clean the ground on the t stat when i get to work on monday and try to round up a p28 auto ecu
Old Aug 1, 2008 | 04:53 PM
strategy400's Avatar
BTW if the wires are all hooked up right and powered and the dizzy is good you should be able to get spark spinning the dizzy by hand (not even bolted on) as long as its grounded.
I bought a high perf dizzy once and the guy behind the counter connected some wires and tested it that way (spun it by hand) and there was strong purple fireworks.
Old Aug 2, 2008 | 11:25 AM
kennyc2189's Avatar
Default Re: 93 civic 2dr ex no spark? (strategy400)
ttt
Old Aug 4, 2008 | 03:47 PM
kennyc2189's Avatar
ideas
Old Aug 5, 2008 | 09:59 AM
kennyc2189's Avatar
UPDATE!! im a dumb *** after being stumped i decided to take apart the dizzy only to find a loose wire to the coil on my "known good dizzy" one of my friends must have decided to take it apart at one time and never informed me of this but on a good not the car is now fixed time to go drink some
93d16
Aug 5, 2017 06:30 PM
dloc82295
Nov 27, 2012 09:14 AM
White0420
Feb 24, 2012 11:13 PM
"goose"jay
13
Mar 13, 2011 05:57 AM
snoochtodanooch
45
Feb 18, 2007 09:21 AM
