Wat is this????? Can i remove it????
Old Aug 1, 2008 | 01:49 PM
Emmanuel2112's Avatar
Default Wat is this????? Can i remove it????
Its an 96 ls. im trying to clean up the engine bay and came across this. i never really noticed it until i looked at it. A friend of mine told me he took his out with no problems. is it safe to take out. wat does it do??
the hose runs to here, but there is nothing actually going into the mnifold its just screwed on there.
Old Aug 1, 2008 | 01:52 PM
denraweb's Avatar
Default Re: Wat is this????? Can i remove it???? (Emmanuel2112)
It's refered to often as the black canister or breather box. Basically it's a type of catch can, and I believe it's baffled. If you remove it, you will need to plug all the hoses that run to it, but no harm if removed. Just put it back for smog, otherwise they wont pass you.
Old Aug 1, 2008 | 02:03 PM
Default Re: Wat is this????? Can i remove it???? (denraweb)
i dont have emision or smog in fl. theres a line that runs thru the firewall and turns into a hard line wat do i do with that???
Old Aug 1, 2008 | 02:39 PM
spklsdb8's Avatar
CHARCOAL CANISTER
Definition: A storage device in the evaporative emissions control system. It is a small cylindrical or rectangular container that contains activated charcoal particles. The charcoal traps gasoline vapors from the fuel tank (and carburetor on older vehicles). Later, the vapors are purged and drawn into the engine when the vehicle is being driven
if i was you i would keep it hooked up if you do unhook it you will smell gas vapors all the time
Old Aug 1, 2008 | 03:34 PM
Default Re: (spklsdb8)
a couple of buddies of mine dont have it and it dont smell like gas or anything. Will it hurt my engine in any way???? Will my vacumm get f******** up
Old Aug 1, 2008 | 03:48 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
not if you plug everything that it connects to.
The hard line runs back to the fuel tank.
I personally would also keep it in place.
Old Aug 1, 2008 | 04:03 PM
steveo135's Avatar
Default Re: (PatrickGSR94)
just throwing this out there dont know if anyone has done it or if its worth it...
how about relocating it? this way you can have your clean engine bay but also have it functioning well too
Old Aug 1, 2008 | 04:19 PM
Default Re: (steveo135)
do only OBD2 engines have this??????? why you guys teling me its ok to remove it but dont do it????? is it really dat bad?????????
Old Aug 1, 2008 | 05:07 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: (Emmanuel2112)
all honda engines have it...
glazedham42
Oct 5, 2005 03:50 PM
dumpeDc2
Mar 11, 2005 11:05 PM
Blown90hatcH
Jun 18, 2003 12:56 PM
RSZero1
Mar 28, 2003 05:52 PM
