Wiring Problems LS In 98 civic DX
Old Aug 1, 2008 | 01:28 PM
crxd88's Avatar
Default Wiring Problems LS In 98 civic DX
As it say's I have a 98 LS engine in my 98 civic dx coupe and I know I need to switch over the 3 wire to a 2 wire on the Idle Air Control switch on the throttle body but don't know which on the civic side will wire up to the integra plug trying to make this motor bar'd in the car so if you know please let me know. Thanks
Old Aug 2, 2008 | 04:06 PM
crxd88's Avatar
Default Re: Wiring Problems LS In 98 civic DX (crxd88)
Come on someone has to of done this swap a million times before me please HELP
Old Aug 3, 2008 | 03:02 PM
RyanA's Avatar
Well, your question is pretty confusing. Are you asking which 2 of the 3 wires you use? Also, you have to pull one wire completely out at the ECU then move another. Do a search for 3 wire iacv and you should find your answer. There are tons of answers to this question; you just need to type a few words in the search engine...
Old Aug 3, 2008 | 09:20 PM
crxd88's Avatar
Default Re: Wiring Problems LS In 98 civic DX (RyanA)
On my car there is 3 wires for IACV but on the integra there is only 2 thats what i was trying to type but didn't so thanks but more info would be appreciated. Also if you know which 2 wires that would be appreciated and which on the harness needs to be changed if you know? Thanks
Old Aug 3, 2008 | 09:52 PM
geebs's Avatar
http://www.ff-squad.com/tech/w...8.jpg
check that link..
http://www.ff-squad.com/technet/
also that link.. it has a lot of info for wiring swaps into civics.
Old Aug 3, 2008 | 10:58 PM
crxd88's Avatar
Default Re: Wiring Problems LS In 98 civic DX (geebs)
Thank you
Old Aug 4, 2008 | 04:17 PM
geebs's Avatar
thats what most of us are here for.
EJ6Coupe92
Aug 7, 2013 01:34 AM
98cwitr
Audio / Security / Video
Jan 15, 2004 12:14 PM
LSturboHB
Oct 18, 2002 06:36 PM
