help with brake swap
Old Aug 1, 2008 | 07:54 AM
97civic94gsxr's Avatar
Default help with brake swap
ok so i want to swap out the front brakes on my DX hatch and i was reading the FAQ and i was wondering when it says an EX/SI/INTEGRA spindle will swap right on is the LS and GSR the same size ? and i have to use the caliper to go along with the different spindle correct ?
Old Aug 1, 2008 | 07:57 AM
EL Vap133's Avatar
Default Re: help with brake swap (97civic94gsxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic94gsxr &raquo;</TD></TR><TR><TD CLASS="quote">ok so i want to swap out the front brakes on my DX hatch and i was reading the FAQ and i was wondering when it says an EX/SI/INTEGRA spindle will swap right on is the LS and GSR the same size ? and i have to use the caliper to go along with the different spindle correct ?</TD></TR></TABLE>
Since you have a DX hatch, to upgrade your brakes you can go with the 99-00 Civic Si, 94-01 Acura Integra (since they are all the same except for ITR), or even 96-00 Civic EX Front brakes. By that I mean the knuckles, calipers, rotors, pads, caliper brackets, etc! Pretty much the whole swap over, you rip your old ones out and put the bigger ones in.
You cannot use any of your DX parts onto the bigger brakes and vice-versa. Member "Brake Expert" however, made a write up on how to keep your DX knuckles and modifying them to make the bigger brakes fit.
superiorx120
10
Jan 4, 2012 09:22 AM
boost and bass
May 25, 2009 07:14 AM
kasperxtcy
Suspension & Brakes
Jan 30, 2008 03:02 PM
Badass240SX
Dec 20, 2004 01:11 PM
Shocka1998LX
Aug 15, 2004 10:43 AM
