EG stock Tach only reving to 6500
hey i just put in a eg gauge cluster in my eg. i had a jdm cluster in it and it worked it fine but didnt like the kil. so i switched them out. i have a gsr motor in my car so i was reving it out and it would only rev to about 6500 rpm it still hit vtec so im thinking that the tach is bad or i dont know if anyone else have thins problem if someone could help me out that would be great thanks
its still reving out to 8200 or whatever stock is but on the tach its only going to 6500 so i think i just bought a shitty cluster that is off cause i know those tachs are off sometimes but i dont think it should be off that much
When you had the old tach in it, do you remember what the tach read when you were going say 55mph (88.5 kph) in fifth gear? If you do you could compare that to the new cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tybird01 »</TD></TR><TR><TD CLASS="quote">When you had the old tach in it, do you remember what the tach read when you were going say 55mph (88.5 kph) in fifth gear? If you do you could compare that to the new cluster.</TD></TR></TABLE>
Yeah, that's your best bet for finding out how accurate (or off) the cluster is.
By using the gear ratios of the trans with your speed, you can calculate the RPM it WOULD be at, deduct that from what your tach is reading and you have the offset.
my gsr-swapped cx does the same... i ran the datalogger on on my hondata s200 system and it reads 8250rpm at the fuel cut (which occurs at ~6500rpm on the ex/si cluster that was swapped in ). at idle its ~100 rpm off, at 5500rpm its already registering ~1000rpm too low and by 8250rpm its even further off at ~6500rpm on the tach
never came across a solution to fixing it... just have to remember to shift at 6500, though a working tach would be nice
m also having the same problem with my ls swapped eg hatch i was thinking ine was the dizzy i bought off egay i know the ecu is good tried a different one also. but never had the car running with the old dizzy hopefully some one can find a solution. i also tried using an after market tach and got close to the stock tach reading ne one else try a different tach?
I'm sure its your tach, i gave my buddy with a gsr swapped hatch my old ex cluster and his tach also shows about 6500 when it hits the limiter of 8200.
I would just try swapping clusters and see if you get any different results.
i had the same problem in my eg,i had a vx cluster and it would go only to 6k then i switch to a si cluter now it would only go to 7k,then i got a jdm cluster and bingo revs to 8.2k
my friend has the same problem, ls swap with ex cluster i believe, but his wont even go pass 5k. got a new ecu and that still didnt fix the prob. its probably the tach so thats the next try..
i have an aftermarket autometer tach laying around... can i run the tach off of the ecu (since thats apparently seeing the correct rpm) and not the blue wire running behind the driver side kick panel (which leads to the tach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tamadrumr88 »</TD></TR><TR><TD CLASS="quote">i have an aftermarket autometer tach laying around... can i run the tach off of the ecu (since thats apparently seeing the correct rpm) and not the blue wire running behind the driver side kick panel (which leads to the tach)</TD></TR></TABLE>
fryman
Jan 24, 2012 09:25 PM
