Compression ratio question
What is the limit on the compression ratio if i wanna install a turbo charger ? ? ?
And for the piping how big should the diameter be ? ? ?
Should i put a air filter on the intake port of the turbo ? ? ? ?
ThankzZ Whoever
ThankzZ Whoever
Depends on how much boost. Higher compression yields more power, but is more difficult to tune.
Depends on how much boost. 2" I.D. is good for over 300hp without any restriction. So, you probably don't need any bigger than that.
Yes, you should use a filter. The compressor wheel is atleast as delicate as the internals of your engine.
[Modified by ion_four, 8:10 AM 7/22/2002]
TehMoonRulz
May 16, 2005 01:15 PM
LSEGHATCH
Oct 6, 2004 07:44 PM
