Compression ratio question
Old Jul 21, 2002 | 10:59 PM
VtecApprentice's Avatar
Default Compression ratio question
What is the limit on the compression ratio if i wanna install a turbo charger ? ? ?
And for the piping how big should the diameter be ? ? ?
Should i put a air filter on the intake port of the turbo ? ? ? ?
ThankzZ Whoever
Old Jul 21, 2002 | 11:09 PM
ion_four's Avatar
Default Re: Compression ratio question (VtecApprentice)
Depends on how much boost. Higher compression yields more power, but is more difficult to tune.
Depends on how much boost. 2" I.D. is good for over 300hp without any restriction. So, you probably don't need any bigger than that.
Yes, you should use a filter. The compressor wheel is atleast as delicate as the internals of your engine.
[Modified by ion_four, 8:10 AM 7/22/2002]
CivicDude2k4
18
Oct 8, 2006 09:13 PM
KOREAN
May 3, 2006 09:00 PM
TehMoonRulz
May 16, 2005 01:15 PM
LSEGHATCH
Oct 6, 2004 07:44 PM
B18C Hatch
Sep 17, 2003 05:41 PM
