always getting power to interior.
Old Jul 31, 2008 | 08:18 PM
tyler100's Avatar
Default always getting power to interior.
when i shut my car off and take the kay out it still beeps and the check engine light stays on. until i pull the wiper arm and it shuts off. WTH is goin on?!
all fuses are good. got all grounds on. in the engine bay. the interior lights ect dont work. the cluster dont work right either. it did before i did my mpfi/a1/crx dash swap. everything worked fine. i really need help H-T./
Old Jul 31, 2008 | 08:35 PM
grog's Avatar
Default Re: always getting power to interior. (tyler100)
you probably mixed up some plugs behind the dash, or maybe you pinched some wires. something from the dash swap for sure.
Old Jul 31, 2008 | 08:38 PM
D16SiHatch's Avatar
Default Re: always getting power to interior. (grog)
yep, what he said. your gonna have to tear that cluster*uck all back apart and figure out where the wiring got crossed. i hate electrical problems like that. good luck
Old Jul 31, 2008 | 09:02 PM
tyler100's Avatar
any idea what plugs coulda been mixed? im gonna pull out the fuse box and re put it all in. when i pull the key out i still get power to the fusebox inside the car. the wiper arm makes the check engine light go. and when i turn on my lights it goes on too.
Old Aug 1, 2008 | 12:20 AM
tyler100's Avatar
Whats going on here. i need help. i got a day to findout whats wrong with this. anybody know somethings that can make this happen? where can wires be crossed?
Old Aug 1, 2008 | 02:22 AM
D16SiHatch's Avatar
their's just too many wires that you were working on back there for anyone to conceivably know exactly where you screwed up. by the sounds of it more than one thing was mixed up. You're going to have to go back over everything you did until you figure out what was messed up.
Old Aug 1, 2008 | 10:46 AM
tyler100's Avatar
Default Re: always getting power to interior. (D16SiHatch)
so take the dash back out? i think thats what im gonna do.
Old Aug 1, 2008 | 11:11 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
How did you figure out removing the wiper arm? Is it creating a ground? Is it 'powered'? (more ways than one).
Maybe play with that a bit...
Old Aug 1, 2008 | 11:33 AM
tyler100's Avatar
Default Re: always getting power to interior. (phoenix_iii)
i diddnt remove the arm. when i pull it like its gonna spray the chech engine light gets brighter. and the engine light and oil light are always on even when i shut my car off. when i flip the turning signals the engine light goes off. and when i push the hazard button i get this loud noise in my speakers. the signal light light up on the cluster but no clicking. but the turning signal arm dont make the arrows go off on the cluster,.
Old Aug 1, 2008 | 11:59 AM
You are changing your description, and not taking the time to explain what happens when. I bet you are doing it from memory and are incorrect as well. No for you
Take the time to research/type it out, and post.
Old Aug 1, 2008 | 12:20 PM
tyler100's Avatar
when i mean i pull the wiper arm i mean like to make the sprayers go my temp gauge goes all the way up when ever i do anything on the wiper side.. my check engine light is always on even when not started. when i push the hazards i hear this loud noise in my speakers. but the hazards dont go. turning signals dont work. my cigg/cluster/cd player lights dont work. theres always a beeping noise. all the fuses are good. power to all of them. i wll make a video when i get off work tonight to show you whats happening. sorry for not explaining right. im just getting a little mad.
Old Aug 1, 2008 | 12:57 PM
tyler100's Avatar
this thing gets really hot. even when car is off.
what does this plug into?
Old Aug 1, 2008 | 11:09 PM
tyler100's Avatar
NO ONE>,.. i officially hate my honda.
Old Aug 2, 2008 | 08:07 AM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyler100 &raquo;</TD></TR><TR><TD CLASS="quote">NO ONE&gt;,.. i officially hate my honda.</TD></TR></TABLE>
just remember who did the labor, its not your cars fault
pick up a good manual with the wiring scheme (like a helms manual ), that should help you fix this.
Modified by grog at 9:12 AM 8/2/2008
Old Aug 2, 2008 | 10:04 AM
tyler100's Avatar
what does the clip go to? and what is the little box that gets hot?
Old Aug 2, 2008 | 11:36 AM
grog's Avatar
the first one looks like the cig lighter relay. probably not the issue, but maybe it shouldnt get hot IDK.
and the second one is the jumper harness for checking CEL codes, which is always unplugged like that.
I imagine you problems are elsewhere, I would focus on the under dash fuse panel and look for similar connectors that could possbly be mixed up. I mean interchangable connectors.
Old Aug 2, 2008 | 12:12 PM
tyler100's Avatar
thanks. i pulled the dash today. i gotta go to work soon so i cant find out what the problem is today. there is a missing connector on the top or the fuse panel. i has 3 big pins. i just dont have anything to go to it., could it be for a sunroof? idk i got all the harness out and everything im gonna mess with it with my dash out. a little easyer. and the harness is from the civic. im not using the crx dash harness. and the harness im using is untouched. not spliced or cut anywhere.
Old Aug 2, 2008 | 12:14 PM
tyler100's Avatar
and if the cigg relay is bad can that make everything else bad?
Old Aug 2, 2008 | 01:49 PM
traxxasx's Avatar
Thats not a cigg lighter relay.
Thats a starter relay switch.
Old Aug 2, 2008 | 03:19 PM
grog's Avatar
I doubt that its as simple as a bad relay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 2, 2008 | 11:25 PM
tyler100's Avatar
Default Re: always getting power to interior. (traxxasx)
im working on it tomorrow. is the starter relay suppose to get hot? and would anyone know what connectors could get mixed up?
zenmark84
Sep 15, 2018 05:57 AM
billdozer79
Sep 12, 2017 01:25 PM
mac_24_seven
Mar 13, 2012 03:34 AM
got00rice
Dec 5, 2009 01:21 PM
JDMDC5888
Mar 27, 2006 01:26 PM
