Starting issue
Old Jul 31, 2008 | 05:09 PM
NACvicSi's Avatar
Default Starting issue
Well I picked up a EK hatch a few days ago. I decided to install a a keyless entry system I had laying around. I got everything hooked up and go to try it and it didn't work. So I figure I might have it wired into a switch port on the fuse panel. Go to start the car and it won't start.
Now the car has a kill switch installed from the previous owner. When I try to start the car the radio and vents and things cut off. Battery is good. It does it also when I have the kill switch plug pulled out. I didn't have the manual so wasn't sure on the pin outs on the keyless so just guessed. Maybe had the plugs wrong?
I unplugged the keyless all together and it still won't start. So I'm thinking fuse (starter fuse was fine), screwy kill switch, or what maybe main relay?
Old Jul 31, 2008 | 09:08 PM
NACvicSi's Avatar
Any ideas?
Old Aug 1, 2008 | 01:01 PM
NACvicSi's Avatar
Found the problem. Had to take half the dash off to get to the kill switch control module, but I found it. One of the plugs came loose.
azspd02
May 27, 2012 06:37 PM
t3to4e
May 17, 2010 03:33 PM
216.226.142.95:27016
Sep 19, 2003 10:16 PM
aw1234dude
Jan 18, 2003 05:17 PM
