Starting issue
Starting issue
Well I picked up a EK hatch a few days ago. I decided to install a a keyless entry system I had laying around. I got everything hooked up and go to try it and it didn't work. So I figure I might have it wired into a switch port on the fuse panel. Go to start the car and it won't start.
Now the car has a kill switch installed from the previous owner. When I try to start the car the radio and vents and things cut off. Battery is good. It does it also when I have the kill switch plug pulled out. I didn't have the manual so wasn't sure on the pin outs on the keyless so just guessed. Maybe had the plugs wrong?
I unplugged the keyless all together and it still won't start. So I'm thinking fuse (starter fuse was fine), screwy kill switch, or what maybe main relay?
