Idle problem after installing front strut bar...could i of damaged throttle cable?
Old Jul 31, 2008 | 01:39 PM
90HondaCRXSi's Avatar
Default Idle problem after installing front strut bar...could i of damaged the throttle cable?
I just installed a PWJDM front strut tower bar in my 90 crx si...and in order to do so i had to push some wires down and lift up the fuse box but then it fit into place and everything bolted down. Now when i start the car the rmp goes to 2,000-3,000 and stays there. How can i get this back to normal?
Old Jul 31, 2008 | 05:37 PM
KDvtec5757's Avatar
Default Re: Idle problem after installing front strut bar...could i of damaged the throttle cable? (90HondaC
check your vacum lines man
Old Aug 29, 2008 | 07:13 PM
Lil Gnome's Avatar
push the throttle body closed to see if the idle goes down if it doesn't then the throttle cable is fine
Old Aug 29, 2008 | 07:24 PM
B16CRXT's Avatar
sounds like you got the brake booster line loose or some other vacuum line. Just double check them all.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
Hackura
Mar 12, 2009 03:17 PM
shooitzlinh
Jan 8, 2005 09:52 PM
douboi
13
Oct 15, 2004 09:16 PM
eknine
Jul 10, 2003 08:36 AM
