4 Wire O2 install
Old Jul 21, 2002 | 09:36 PM
EF_LSVtec's Avatar
Default 4 Wire O2 install
I have the color coding diagram...Green and black (ground), white (signal), black (switched power)...Where can I tap the other black wire to get power to the heated O2 sensor? I was reading a honda manual and a wire colored yellow and black is for switched power...I just want to make sure before I start connecting or splicing any wires.
Old Jul 21, 2002 | 09:41 PM
samiam's Avatar
Default Re: 4 Wire O2 install (EF_LSVtec)
Just find a swithced 12 volt dc power source.
Old Jul 21, 2002 | 09:46 PM
EF_LSVtec's Avatar
Default Re: 4 Wire O2 install (samiam)
I already know that...sorry, but I wasnt clear on my question...is there any switched power wire in the engine compartment that I can tap on? Alternator, distributor, sensors, relays? which one sensor, which part and what color wire?
Old Jul 22, 2002 | 01:20 AM
EGHatchy's Avatar
yea, i'd like to know also..
Old Jul 22, 2002 | 08:24 PM
samiam's Avatar
you can try the yellow and black wire on the distributor harness. Use a test light or dvom to be sure.
Old Jul 22, 2002 | 08:54 PM
xci_ed6's Avatar
or at the injectors, or at thefuse block (i think)
-Dustin
Old Jul 22, 2002 | 09:07 PM
02WRX's Avatar
Default Re: 4 Wire O2 install (Autocratic_1st_Gen)
In the main fusebox at the fuel pump...
Eric
Ronan
May 22, 2007 08:48 PM
elmalouno
11
Aug 18, 2004 09:06 AM
alexb16hb
Mar 23, 2004 01:48 PM
bdicustoms
May 21, 2003 02:52 PM
loworbitSI
Oct 9, 2002 10:41 AM
