any advantages??
Old Jul 30, 2008 | 04:38 PM
jon4honda's Avatar
Default any advantages??
are there any big advantage's to cutting your shifter down shorter??its a stock 4 speed that came in the 1989 honda civic hatchback people been telling me it helps your short throws but idk thank's in advance
Old Jul 30, 2008 | 04:42 PM
BILLETGRIP's Avatar
Default Re: any advantages?? (jon4honda)
no it wont be the same as a short throw. you lengthen the part of the shifter under the pivot point to achieve a short throw shifter.
Old Jul 30, 2008 | 06:10 PM
mit7059's Avatar
That would just be the same as gripping further down the shaft, yes I guess the distance you move your hand would be shorter but it would also require a lot more effort because by shortening the lever length you have to use more force to create the same amount of torque. This would probably result in it taking you longer to shift and making your arm tired.(sorry to get all physics-y)
Old Jul 31, 2008 | 05:27 PM
jon4honda's Avatar
anyone else have a opinion??
Modified by jon4honda at 7:05 PM 8/5/2008
iwantspeed
Honda Civic (2001 - 2005)
Jul 27, 2006 08:15 PM
lacking vtec
Feb 11, 2006 07:36 AM
LD_EGSICK
Jun 25, 2002 12:31 PM
tdog
Feb 11, 2002 06:35 PM
Tommy_Gunns
Oct 11, 2001 05:18 AM
