WILL 99-00 SI REAR WHEEL BEARINGS FIT GSR
Old Jul 30, 2008 | 01:00 PM
Sloshy's Avatar
Default WILL 99-00 SI REAR WHEEL BEARINGS FIT GSR
I have a set of 99-00 si rear wheel bearings but my car has gsr rear disk and trailing armS, so i want to know if the si bearings will work the only difference i can between the is the ABS ring..
Old Jul 30, 2008 | 01:11 PM
pdiggitydogg's Avatar
Simply, all rear disc components are the same.
So, yes (meaning, you also dont have "gsr" rear discs)
For example, I have a used DA rear bearing on my hub, right now
Old Jul 31, 2008 | 06:31 AM
Sloshy's Avatar
Default Re: (pdiggitydogg)
ok sounds good im going to get them in this weekend..
Old Aug 1, 2008 | 11:03 AM
Sloshy's Avatar
I've been lookin at part numbers on an line category they look different.. anyone else so i can be sure know for sure
Old Aug 1, 2008 | 12:59 PM
dude...theyre the same...
Of course the part numbers will differ...one has an abs ring. Theyre exactly, 100% identical otherwise.
sparkylawdog
Mar 26, 2014 08:53 AM
KdiZzLe
Jun 20, 2010 11:22 PM
lowgman
May 18, 2005 12:47 PM
Jesse 99EK
Nov 10, 2003 08:25 AM
fearthegerbil
Oct 7, 2003 02:42 PM
