Smoother idle?
Old Jul 30, 2008 | 11:29 AM
Tyson's Avatar
Default Smoother idle?
so after replacing my spark plugs, cap and rotor im still getting a bit of a misfire, stumble, just inconsistent idle. like every 3-5 seconds the vibration will blip a bit and i can feel it. VERY minor, its not horrible. im just being really picky and want to know, what ELSE is there to do?
my valves are tapping a bit, i could do a better job next time. but does this affect idle?
idle is set at 750. timing is right in the middle.
what else can i look into? cleaning sensors? which, how?
88 Si intake manifold, so i think its missing a sensor or two that may or may not matter.
i just want it to PURRRRRR....
Old Jul 31, 2008 | 06:01 AM
Mr.Death's Avatar
Default Re: Smoother idle? (Tyson)
Having a similar problem. Curious, what motor/ecu are you using?
Old Jul 31, 2008 | 09:21 AM
ktp1598's Avatar
Spark plug wires could cause that. I bought a car that would not rev over 2k. It was just the wires.
Old Aug 7, 2008 | 04:59 PM
Tyson's Avatar
Default Re: (ktp1598)
im starting to think that as well.
http://www.crxcommunity.com/vi...light=
i replaced my #1 plug wire with a spare i had laying around and it does seem a bit more settled. so i guess that had a lot to do with it.
plug wires are definately important!
and i have a new set of NGK's in my hand. but i wonder about the quality of these wires now... when i pulled the old NGK wire off, the plug at the distributor came off!
Old Aug 7, 2008 | 05:45 PM
Natural Aspirations's Avatar
Crappy valve seal (valves sealing to seats) may also be your issue. How many miles are on your head?
Old Aug 7, 2008 | 06:10 PM
Tyson's Avatar
Default Re: (Natural Aspirations)
the engine is in pretty good shape actually. i call it my cherry engine. got it with only 45k verified miles in 2002. used it for 2 years and stored it and just recently put it back in. so cant have too many more miles. but i did do a season of racing in those 2 years.
smog is great with the engine btw. its still almost 20 years old of course.
dointhemzs
Sep 7, 2008 07:09 PM
Mik3
Feb 5, 2006 06:55 PM
Br1anPham
Feb 1, 2004 10:15 PM
yee SERIOUS
11
Jul 27, 2003 11:39 AM
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
