anyone install bilsteins?
i want to lower the perch on my bilsteins and am having trouble figuring it out...
do i hit the perch down with a hammer and then take off the clip? also what tool would i use to remove that clip?
thanks
thanks
You hit the perch up, this will expose the clip. THen you can move it down, it can be done with a small screw driver or a tool thats designed for circlips.
Slide the perch towards the top of the shock to expose circlip. Don't see why any hitting would be involved. I use needlenose pliers to move the circlip from one groove to another.
It looks like you need to compress the spring a little more to get at the cirlcip.
well the reason i asked is because i hit it with a hammer and it wouldnt budge at all...i really dont feel like tearing it all apart...
thanks for the help...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx(gator) »</TD></TR><TR><TD CLASS="quote">well the reason i asked is because i hit it with a hammer and it wouldnt budge at all...i really dont feel like tearing it all apart...
soak it in WD40 or PB Blaster, wait few hours then using equal force try to push it up/ on it. you should be able to free it.
</TD></TR></TABLE>soak it in WD40 or PB Blaster, wait few hours then using equal force try to push it up/ on it. you should be able to free it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">they look just like koni yellows
what car you putting those things on man?</TD></TR></TABLE>
Well it is the Miata forum...I would guess his "Tyte" car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">damn it I had these and you could lower them?? wtf</TD></TR></TABLE>
Only on some applications. I think the ITR and NSX Sport's have multiple perch grooves per shock. My Prelude application Sport's only had one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Infinity- »</TD></TR><TR><TD CLASS="quote">
Well it is the Miata forum...I would guess his "Tyte" car.</TD></TR></TABLE>
well i guess i dont know him dousche... and he doesnt have a hype R which is why i was asking!
im putting them on my 95 civic si...lol, didnt lower em at all...i didnt think it would cause of the weight difference...
i got all the perches down, however im dealing with more headaches...one of the lug nuts broke thanks to some ******* at pep boys over tightening that ****...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">sweet set up? itr springs, if so they will make that thing look like a 4x4 due to the weight differences</TD></TR></TABLE>
eibach pro kits. i didnt want to be slammed, id figure it would give me about an inch drop. maybe it lowered overnight lol...
