C Clip on Konis
Old Jun 19, 2001 | 05:00 AM
Lewd Lude's Avatar
Default C Clip on Konis
How do I remove the c clip on the spring perch?
If I do remove it, can I reuse it? Im worried they will be weakened.....
CUrrently they are on the middle perch, and I want to use the lower perch...
Thanks
Old Jun 19, 2001 | 05:17 AM
DR's Avatar
DR
Default Re: C Clip on Konis (Lewd Lude)
You do not remove the C clips just to make an adjustment. Get some plyers and take one side of the C clip out of the groove and put it in the next lower or higher groove. Then take the other side of the C clip and move it to that same groove.
Old Jun 19, 2001 | 02:51 PM
mike2016's Avatar
New User
Yes you can reuse it, mine has been taken off twice before because the shop messed up the height... no problem so far...
crx(gator)
Aug 1, 2008 08:11 PM
giff74
Mar 19, 2005 02:09 AM
seanb18c1
Sep 10, 2003 10:20 PM
Lewd Lude
Jun 19, 2001 08:57 AM
