supercharge a b16 del sol
Old Jul 29, 2008 | 04:01 PM
bigtom388's Avatar
Default supercharge a b16 del sol
i have a 2000 si b16 swapped into my del sol it has a fresh rebuild only 9000 miles on it with port and polish valve job pretty much built except for sleeves i have a blox raxcing intake manifold power chamber intake and full header back exhaust and 310cc injectors i wanna supercharge it cuz its safer then a turbo i just want sum opinons on this or any help about it
Old Jul 29, 2008 | 04:43 PM
vtecb18c's Avatar
Default Re: supercharge a b16 del sol (bigtom388)
superchargers are ok...they make descent and reliable hp but it seems like on hondas they just dont cut it...just my opinion
*although there was a pretty nasty jrsc'd rsx on youtube but thats k-series
Old Jul 29, 2008 | 04:49 PM
Gunmetal_B20_Hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigtom388 &raquo;</TD></TR><TR><TD CLASS="quote">i wanna supercharge it cuz its safer then a turbo i just want sum opinons on this or any help about it</TD></TR></TABLE>
False...
And stop typing like a 15 year old.
Old Jul 29, 2008 | 04:52 PM
vtecb18c's Avatar
Default Re: supercharge a b16 del sol (Gunmetal_B20_Hatch)
gunmetal....they really arent safer than a turbo?? i heard that they were but if you could explain it to me that would help me out....im all about learning new things
Old Jul 29, 2008 | 04:57 PM
bad tune on a S/C is just as unsafe as a bad tune on a snail.
Old Jul 29, 2008 | 05:02 PM
vtecb18c's Avatar
Default Re: (Gunmetal_B20_Hatch)
oh well obviously a bad tune on anything will fry a motor...i was just wondering what the cons were on a blower....i've heard nothing but good things(besides making more power with a turbo) with a blower....i heard it was safe and reliable....but than again its the same for a turbo...so really the pros and cons are the same with a blower and a turbo?
Old Jul 29, 2008 | 05:50 PM
nix94delsol's Avatar
Default Re: (vtecb18c)
Turbocharge a 4 cylinder
Supercharge an 8 cylinder
Screw a 6 cylinder
Thats all i have to say
oh and BTW if your going with the JRSC you might as well spend the little bit more and buy an edlebrock kit
Old Jul 29, 2008 | 05:58 PM
vtecb18c's Avatar
Default Re: (nix94delsol)
heard some good things about the edelbrock kit, but im an s trim fan if i was gonna do it...like vortech
Old Jul 29, 2008 | 06:05 PM
slvrcvc93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">heard some good things about the Edelbrock kit, but im an s trim fan if i was gonna do it...like vortech</TD></TR></TABLE>x2 If you dont wanna get to crazy the jackson setup is good but doesnt have as many options as the Vortech unit ive seen that setup do 600hp and the Jackson racing unit the highest I have ever seen was about 378 and I believe it was a stroked b16 (1.6 to 2.0)so the motor had some serious work.
Old Jul 29, 2008 | 06:40 PM
vtecb18c's Avatar
Default Re: (slvrcvc93)
yea root styles just dont cut it on hondas for some reason
Old Jul 29, 2008 | 07:24 PM
Frickr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">yea root styles just dont cut it on hondas for some reason</TD></TR></TABLE>
its because they spin counterclock wise and only a few blowers were made that spin counter clockwise. just like a small turbo can only make so much power the blowers are limited on power
Old Jul 29, 2008 | 07:34 PM
vtecb18c's Avatar
Default Re: (Frickr)
so my suggestion is go s trim if anything
Old Jul 29, 2008 | 07:42 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">Turbocharge a 4 cylinder
Screw a 6 cylinder
oh and BTW if your going with the JRSC you might as well spend the little bit more and buy an edlebrock kit</TD></TR></TABLE>
There's some award winning logic .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">gunmetal....they really arent safer than a turbo?? i heard that they were but if you could explain it to me that would help me out....im all about learning new things </TD></TR></TABLE>
They aren't safer than a turbo, no. Untuned, both a turbocharger and a supercharger have an equal chance of raping your motor.
If you're trying to learn things, I suggest A) You PM certain members, B) You google, and C) Don't post general questions here.
The pros and cons on a low displacement 4 cylinder engine are quite clear. The major upside is it raises your power throughout the entire power band, so it feels like you have a stronger motor in there, opposed to a turbo which gives you more power, but only mid-high up.
Superchargers give you a good feeling like you have a solid naturally aspirated application, that's all motor, while turbos make their peak HP at peak RPM, so you really gotta wind it out - down at low RPM they aren't even compressing.
Old Jul 31, 2008 | 12:07 PM
bigtom388's Avatar
thanks guys helped out alot ill prolly go with the turbo then. nother ? tdc keeps coming when i hit high rpms but not all the time put a new dizzy on it same thing any ideas. o and gunmetal ill type how i want if u cant understand it thats ur fault no one else has a problem with it
Robierto
Jul 26, 2009 04:41 PM
bigtom388
Apr 9, 2008 05:17 PM
bigtom388
Feb 15, 2008 01:41 PM
one bad dx
Northeast (Sales)
19
Jul 7, 2006 08:42 AM
deca
18
Jan 26, 2005 09:02 AM
