Koni Yellows
Old Jul 29, 2008 | 12:55 PM
shadhman's Avatar
Default Koni Yellows
Hi,
I got a set of Koni Yellows and when i was puting in the fronts or should I say trying to put them in; the circumference of the base of the shock was to large to fit in the fork. I stretched open the fork a good 1/2-3/4 inch and the shock still wouldnt fit. Am I doing something wrong? Should the Koni's fit in the forks without any manipulation?
Old Jul 29, 2008 | 12:58 PM
xelloss's Avatar
Default Re: Koni Yellows (shadhman)
are you buying the right shocks for the rigth car?
I'm also using Koni on my 99 4 doors...but Red. Shouldn't be any mods need to install them..
Old Jul 29, 2008 | 01:33 PM
00ekcoupe's Avatar
Default Re: Koni Yellows (xelloss)
You shouldn't be having any problems at all. The struts are probably not for your car.
Old Jul 29, 2008 | 02:30 PM
shadhman's Avatar
Default Re: Koni Yellows (00ekcoupe)
Yeah thats what I was thinking. Luckily the company I got the shocks from is working with me to figure out the problem. I will let you guys know the outcome.
Old Jul 29, 2008 | 02:38 PM
iluvmy2000civicex's Avatar
What company did you buy from?
You didnt damage you fork from playing with it to try to get them to fit did you?
Old Jul 29, 2008 | 03:50 PM
nekoabandoned's Avatar
Default Re: Koni Yellows (iluvmy2000civicex)
its hammer time ><"
Old Jul 29, 2008 | 04:24 PM
shadhman's Avatar
Default Re: Koni Yellows (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmy2000civicex &raquo;</TD></TR><TR><TD CLASS="quote">What company did you buy from?
You didnt damage you fork from playing with it to try to get them to fit did you?</TD></TR></TABLE>
It did get a bit warped to the point i couldnt get the bottom bolt in but after i put the bolt in that secures the shock it straightened it out luckily.
I will post pics of the shock. I googled the part numbers that were on the outside of the box as well as confirmed with the seller that the box serial numbers are right. The only conclusion i can come to is that they may have been mixed up before they got in the box.
IS there a serial number or anything I can see on the shock that will confirm the fitment?
&lt;br/&gt;
Modified by shadhman at 11:54 PM 7/29/2008
Old Jul 29, 2008 | 10:26 PM
shadhman's Avatar
Is there any numbers on the shock that you can use as a reference for there application?
NVM found it and it matches the box which matches the fitment for my car. So why won't they fit?
Modified by shadhman at 11:22 AM 7/30/2008
Old Jul 31, 2008 | 04:54 PM
xchipx's Avatar
well newbie here all the way from the united kingdom ! but i just had to register upon spotting this post - i share the exact same problem..... but dont get your hopes up yet because i have not worked it out yet either.
let me guess the problem is the welds around the bottom of the damper ? either way if you clamped it to the welds it wouldnt hold. also look inside the damper fork, there is a lip at the bottom that doesnt seem to let the damper through properly - again wouldnt hold properly. i think i am going to have to machine out my forks or let the damper slide lower ( after removing the forks inner lip ) and then dent the damper so the bolt will go through the fork. whether or not that will sort the problem i dont know - i will keep you updated . by the way i am talking about a 1990 model crx vtec, my forks should be even narrower than yours ! are your dampers the off car adjustable forks by the way? mine are but i have confirmed with koni themselves that these are the right damper for my car etc
regards
mark
Old Jul 31, 2008 | 05:35 PM
mikeycivic's Avatar
what kind of car are these trying to be installed on?
Old Jul 31, 2008 | 06:25 PM
shadhman's Avatar
Default Re: Koni Yellows (mikeycivic)
K
Update this is resolved.
It ended up being that the guy who owned the car before me put EF damper forks on for a lower drop. I bought a set of EG 92-00 front damper forks and It's all good now!
Props to Innes the guy i bought the shocks from for helping me out through the process and having great customer support. If you need koni's search his name
Diamond Co
Suspension & Brakes
May 11, 2012 11:26 AM
team_hirev
Suspension & Brakes
Mar 5, 2009 09:41 AM
ph0shizzle
Nov 2, 2006 07:06 AM
tegrunner
Jun 10, 2005 02:48 PM
ichibano
May 15, 2002 07:38 PM
