High pitch squealing
I have a 89 Si. Just had the motor swaped. Sometimes when I drive theres a really loud high pitch squealing sound comming from I think under the hood. If i touch the brake or give it gas it stops. When i slow down to a roll the squeak slows to my speed. It dosent sound like brakes i was thinking something with the axles. It does it off and on sometime it sound good sometime not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">sounds like a belt </TD></TR></TABLE>
x2.
is the type of squeel you hear in parking lots coming from old cars that are turning slowly?
thats the belt. theres only 2 belts, ac and alternator. probably the alternator.
loosen the bolt, push to stretch and tighten. easy.
x2.
Its not the belt because if i go slow like 5km the squeak squeak sound slows down with the car speed. im thinkiing brakes or something with the axles because of the swap.
then check your brakes...
are you lowered? rotor shields have been known to rub when extremely lowered. or things are installed incorrectly.
Modified by Tyson at 2:56 PM 7/29/2008
From: Close to West Chester, PA, United States of America
Mine was directly proportional to wheel rotation, would sometimes go away while turning, etc.
Front wheel disc protector bent and touching rotor... Go figure. sounded like out of round brake drag. Squeak-a squeaka squeaka.
Modified by phoenix_iii at 3:11 PM 8/12/2008
So i called the guy looking at it, said that is was a loose wheel? I dont know how it can be loose if i used a torque wrench! Well see wtf ehen i pick it up.
So he said all he did was tighten the **** out of the wheel nuts. wtf?? I dont know hoow that would make a squeek or grinding sound but it dosent make the noise now.
jaydem7
Aug 13, 2007 04:14 PM
