00 Type-R cams in 99 b16, worth it? And need valve adjustment?
Old Jul 28, 2008 | 08:54 PM
91EF_Si's Avatar
Default 00 Type-R cams in 99 b16, worth it? And need valve adjustment?
I have a 99 Si b16, with basic bolt-ons. I have 00 ITR cams, and was wondering if they are even worth putting in. I'm not looking for crazy power off them, I just have them sitting here so..why not? Do I NEED a valve adjusment, will my motor be safe with stock valve train at stock rev limit? Please input opinions. Thanks!
Old Jul 28, 2008 | 09:51 PM
91EF_Si's Avatar
Default Re: 00 Type-R cams in 99 b16, worth it? And need valve adjustment? (91EF_Si)
Old Jul 28, 2008 | 09:56 PM
XxNampsterxX's Avatar
Running stock valve train, you don't have that many options. Its going to be stage 1 cams or ITR, which are really similar already. ITR's a good if you want to stick with stock valve train. You'll see a power difference and you will probably need a valve adjustment after the install.
Old Jul 28, 2008 | 10:11 PM
jasoncrashtech's Avatar
Default Re: 00 Type-R cams in 99 b16, worth it? And need valve adjustment? (XxNampsterxX)
stock valves will work fine, but you will need to adjust your valves.
Old Jul 28, 2008 | 10:14 PM
Ek9LbC's Avatar
bump
Old Jul 28, 2008 | 10:18 PM
Ek9LbC's Avatar
bump
Old Jul 29, 2008 | 04:28 AM
na+b18c_hatch's Avatar
i say if you already have them, i don't know why they're not installed yet lol.
Old Jul 29, 2008 | 07:06 AM
91EF_Si's Avatar
Default Re: (na+b18c_hatch)
lol, i want to install them...but i don't know how to do a valve adjustment nor do i know the specs.
Old Jul 29, 2008 | 07:13 AM
Default Re: (91EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">lol, i want to install them...but i don't know how to do a valve adjustment nor do i know the specs.</TD></TR></TABLE>
have any tech friends? get someone to help you if you can, instead of taking it to a shop.. that way you can help and learn how to do it yourself. its really not that hard. as for the specs... do a search, i'm sure you can find them on h-t somewhere.
Honda-bond
32
Jan 22, 2011 02:45 PM
91EF_Si
Aug 5, 2008 07:03 PM
skata89
Nov 27, 2006 09:03 AM
