i need some ideas for my air flow to my radiator
with the bumper off, i keep temps down to 195 whlie boosting, 188-190 cruising.
bumper on.....the highest it got was 216
i have a fal fan so im good there. never over heated but 216 is too high. i purposly drove it at 102 dg out.
its an air flow issue, what ideas do you guy have. i dont mind cutting in the bumper. i was thinking about cutting right above the IC. TIA
yeah it's datalogged. yeah im thinking of some kind of duct. pretty much kinda like something that vettes have. im going to drive it with the bumper off until i figure out something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">that still does not put air flow to the radiator, it needs direct air.</TD></TR></TABLE>
Uh, yes it does, all of that air that goes to that space will be directed into the half rad.
You can also try having a pusher and a puller fan, moving your intercooler back/rad forward so that they are touching each other, using water wetter, adding a switch to your fan so that you can turn it on all the time for hot days, using all water during the winter. I'm probably missing something, but if you have overheating issues after doing all this you've got other problems.
read up....it never overheated. i just dont like the temp. it only reached 216 for a very short time, went back down to 208 which i still dont like
its on a switch
i dont need a pusher puller.
dont need to use just water....
the problem is airfow
drive with the bumper on....higher numbers
take the bumper off....195. i tried to heat it up, wouldn't go, so air flow is the issue
now bump for airflow ideas
its on a switch
You have a few options. The gay Super Duper JDM hood prop, a gay hood with a scoop and neither is guaranteed to work. Or make some sort of ducting around the radiator to catch optimal air flow. I will try and find this picture to show you exactly what I mean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">read up....it never overheated. i just dont like the temp. it only reached 216 for a very short time, went back down to 208 which i still dont like
its on a switch
now bump for airflow ideas</TD></TR></TABLE>
Put a piece of sheet metal next to the half rad, put a pusher fan on it, cut out your bumper bigger, prop your hood, take your hood off, vent your hood, put in water wetter, put in all water, don't take any of my advice at all because none of my suggestion will take 5* off of your coolant temps and get you into a "comfortable" range even though the temps you are seeing are extremely normal for a 102* day.
its on a switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">what do you guys use for that hood prop mod? longer screws and a spacer</TD></TR></TABLE>
YES
YES
Any spacer will do. I did this to my s2k works well. Also remove the rubber seal in the rear cowl panel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">yeah im thinking something like that. I'd just have to cut more where my radiator is.</TD></TR></TABLE>
exactly
exactly
whats the best tool for that. I have an air grinder but the wheels doesn't seem to like that material that much plastic that much
210-215 isn't TOO hot..
My dsm sees 210-215 all the time, when im in traffic and its idleing. Im considering cutting the bumper also, i don't like that high of temps, although again there not TOO hot.
My car just makes so much damn heat it seems, ive got a 10 and 12" slimfans both pullers, and a full rad and everything under the hood is coated/and or wrapped!
Goodluck.
Goodluck.
i think i just figured it out....
on the left side of the picture where the bumper support is. That is almost like a natural scoop.
Im going to cut a hole on both sides of my bumper right at the end of my bumper support. Kinda like a ram air set up.
Im going to use some type of flexible duct like a dryer vent type stuff. maneuver it through the bumper and behind the bumper support directly on the IC.
Im going to do the same for the other side and run a duct back in front of the radiator for uniformity and more air.....tell me what you think. Im at work and hopefully i can start on it tommorow
