need help with turbo ls vtec
Old Jul 28, 2008 | 03:52 PM
30lbsboosting's Avatar
Default need help with turbo ls vtec
car doesn't start.
had the car out about a week ago
it was like 95 + degrees in ny
the dam car shut off on me at the light wasnt even boostin on the car jus drivein
doin like 30.
checked every thing new main relay, different ecu , all the fuse are good
cant check cel's
cus i have a solid check engine light
no spark, and no fuel pump u kno the enitial sound when the car is primed on the on position.
jus a solid check engine .... that means ECU ....but the car cranks so it is not a ground wire....
HELP ME HONDA GODS..NEED SOME FELLO TECH ASSISTANCE
Old Jul 28, 2008 | 04:01 PM
almostboostedgsr's Avatar
Default Re: need help with turbo ls vtec (30lbsboosting)
Double check all your wiring. Id start with making sure the thermostat has a ground. Then move on to making sure all the sensors on the back of the block are plugged in.
Also what are you using for engine management?
Old Jul 28, 2008 | 04:07 PM
f22beast's Avatar
I had the same exact thing happen to me last summer.
This may seem odd but it turned out that a fuse fell out, (Im Assuming; I still havent found it.) i put a fuse back in the one labled ACG fuse. and the car fired right up. Search for my thread for better info it was called ;ACG fuse WTF Story.
Jeremy
Old Jul 28, 2008 | 08:46 PM
jdong's Avatar
just barrow an ecu and try it.... sounds like its ecu to me.....
Old Jul 29, 2008 | 05:54 PM
thanks guys just fix it tonight
had to reset the ecu
removed the ecu fuse and disconnected the batt...
the first time all i did was swaped ecu's
and removed ecu fuse.... the code is stilled saved and stored
so when i pluged the new ecu it did the same thing
the old one is fried...
thanks alot guys i know i can count on honda tech
Si_Element
Sep 6, 2006 12:10 PM
Quick.Silver
May 24, 2006 11:56 AM
LOWLIFEHATCH
Sep 1, 2004 06:48 AM
VanishSupra
Sep 4, 2003 11:19 PM
