What code is this? Running very rich and bogging! Help!
Old Jul 28, 2008 | 05:24 PM
All-Motor-Junkie's Avatar
Default What code is this? Running very rich and bogging! Help!
ok some basic info, 93 si lude, si harness, jdm f22b SOHC from HMO
car runs but wont always stay on bogs and dies then struggles to start. when it does start i get a CEL. when i try to pull the codes, it constantly stays on. at first i though this was a code ) and ECM just took a crap for no reason, so i put a p14 i had lying arround that i know works 100% and still same code im getting. its not FPR or injectors, im assuming maybe the harness is just crap? any ideas greatly appreciated! TIA!!!
All motor junkie
Old Jul 28, 2008 | 05:37 PM
speedracer9k's Avatar
check all your harness connectors. make sure they are all pluged in correctly and in the right place. also you might want to check your coil and ignitor
Old Jul 28, 2008 | 09:17 PM
mizlude's Avatar
It may be your TPS, does it bog until you reach 3000rpm and up? Oh and I bet its burning through a 1/4 tank of gas in no to also.
The first thing you should do is check out your tps and it its junk go to inlinefour.com and pick up one of there tps (its way cheaper then buy at new t-body from honda) then change your plugs. My car did this same thing two winters ago and thats what it ended up being.
Tactic$
May 20, 2006 09:45 AM
dohcdelsol93
Oct 27, 2004 10:27 AM
JDM EJ1 95
10
Jul 11, 2004 12:51 PM
B18C-RnVA
Apr 28, 2002 03:38 PM
GeeSeeR
Aug 7, 2001 11:06 PM
