Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Offset and sway bar questions
Old Jul 28, 2008 | 11:30 AM
MARVNVRAM's Avatar
Default Offset and sway bar questions
1. I'm buying a set of slipstreams for the R in 15x7 and wanted to know which offset to go with for autox, 40 or 35?
2. Being that my R is a theft recovery with no sway/strut/lower tie bars at all, I wanted to pick up an oem complete set just for the sake of putting the R together stock. But the thing is, I've spent a lot of time tuning my suspension how I want it without the bars (if it helps I'm on Koni/GC's). How drastic will the car change after adding all these bars?
Thanks for any help you guys can give.
Old Jul 28, 2008 | 11:45 AM
VTECIntegra9's Avatar
sway bars will drastically change and improve your handling. The strut/tie bars will do less but still improve response.
Old Jul 28, 2008 | 12:36 PM
get RIGHT's Avatar
Default Re: Offset and sway bar questions (MARVNVRAM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARVNVRAM &raquo;</TD></TR><TR><TD CLASS="quote">1. I'm buying a set of slipstreams for the R in 15x7 and wanted to know which offset to go with for autox, 40 or 35?
Are you sure the offset was +35 and not +38?
Old Jul 28, 2008 | 01:11 PM
cxhb1's Avatar
buy a good sized rear sway bar. keep the front stock. the car will feel a LOT better.
Old Jul 28, 2008 | 01:55 PM
STN_Pat's Avatar
Default Re: (cxhb1)
Add both front and rear OEM ITR if you like the actual balance.
Old Jul 28, 2008 | 02:17 PM
NTCustoms's Avatar
gonna have to retune because sway bars will drastically improve your handling. get the lower offset
Old Jul 28, 2008 | 02:34 PM
MARVNVRAM's Avatar
Default Re: (NTCustoms)
As for offset, I originally wanted a 38 but Rota doesn't make them. 35 and 40 are my only options but was worried I would run into rubbing issues with the 35. The R is a tad lower than stock.
And the sway/strut/lower tie bars are all OEM. I have it setup now very neutral but I guess I will need to retune once I slap those on.
Old Jul 28, 2008 | 02:46 PM
STN_Pat's Avatar
Default Re: (MARVNVRAM)
get the 40mm and add spacers if you want them 35.
OEM R are +50 15x6
Old Jul 28, 2008 | 02:52 PM
suprmods's Avatar
get +35, you wont have any problems.
Old Jul 28, 2008 | 03:39 PM
MARVNVRAM's Avatar
Default Re: (suprmods)
Thanks for your help guys
Old Jul 28, 2008 | 11:10 PM
NTCustoms's Avatar
dont see why you would want to run spacers with a 40mm when they already make them in a 35mm.....
Old Jul 29, 2008 | 10:07 AM
MARVNVRAM's Avatar
No I don't want to deal with spacers. I don't daily the R so running a 35 won't bother me.
Old Jul 29, 2008 | 01:42 PM
STN_Pat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms &raquo;</TD></TR><TR><TD CLASS="quote">dont see why you would want to run spacers with a 40mm when they already make them in a 35mm.....</TD></TR></TABLE>
Because his main concern was the fitting of the +35...if the +35 rub, he's [freak]ed.
I know they probably will fit, but he wanted to be sure of it.
The solution I proposed cannot fail.
Do you understand better now ? I can make a graphic !
Cream
50
Apr 5, 2011 02:17 PM
austinkli
Suspension & Brakes
Mar 22, 2010 07:00 PM
Tunerguy1989
Apr 30, 2009 11:25 AM
fluke83
Jul 6, 2004 03:13 AM
01gizzer
May 29, 2002 01:27 PM
