2 part question
i have a manuel but i do not have new head bolts and i need my car asap does anyone know how much old stock head bolts should be torqued at
CYLINDER HEAD BOLT TORQUE SPECS (tightening) / (loosening)
8, 4, 2, 6, 10 <---intake order 3, 7, 9, 5, 1
7, 3, 1, 5, 9 <---exhaust order 4, 8, 10, 6, 2
Torque in steps: 22ft-lbs (264in-lbs), Then to 63ft-lbs (756in-lbs) (final spec) 94+ Teg
Torque in steps: 22ft-lbs (264in-lbs), Then to 61ft-lbs (732in-lbs)(final spec) 90-93 Teg / B16's
If you overtighten them you get mad extra vtaks...
^ false information
If you look in the integra forum FAQ you can find the correct torque specs and you'll be fine... but if you want an answer to those two questions...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveharrmr23 »</TD></TR><TR><TD CLASS="quote">what is the result of under torqing my head bolts
what is the result of over torqing my head bolts</TD></TR></TABLE>
TROUBLE
^ false information
TROUBLE
i am asking because i know that some have reused the stock ones and i know the other half use new i am trying to find out from someone who reused the stock ones how much the final torque was
