I need susp set up for 87 hb
Im guessing you mean aftermarket? OPM motorsports has a lot of suspension stuff for 84-87 civic/crx's. For the front many companies make struts for them i.e., Tokico, Koni and KYB and OPM has 22 and 27 mm torsion bars. I know that Ground control makes coilovers for the rear. Check out OPM though they offer a lot of suspension upgrades.
23mm torsion bars from Ground Control or OPM, rear coil over kit from OPM, Tokico or Koni adjustable shocks, remove front sway bar, add rear sway bar (I like the 19mm Addco bar), and Energy Suspension bushings. This will give you a killer suspension.
http://www.opmmotorsports.com
http://www.ground-control.com
Check out http://www.redpepperracing.com We are 84-87 Civic/CRX freaks over there.
[Modified by crxfanatic, 2:43 PM 7/22/2002]
Sorry, should have clarified. If you're autocrossing you should remove the front sway bar. For street and track, you may want to leave it on.
Reason? If you remove the front sway bar you reduce understeer. Same reason for adding a rear sway bar, you increase oversteer.
Generally stiff front = understeer, stiff rear = oversteer. Manufacturers dial in understeer because it's safe for the general non-enthusiast public. This is bad for optimal race oriented front drive handling.
HTH
HTH
604Squad
41
Jan 1, 2006 01:50 PM
thehatchninja
10
Dec 23, 2002 12:08 AM
Rratedcivichatch
12
Aug 23, 2002 08:30 PM
