Stock or Lightened flywheel
Changing the clutch right now, and wondering if I should ditch the 8 or 12lb (not sure) Clutchmasters flywheel and go with stock, or keep the Clutchmasters.
I've heard people say that stock flywheel is good for drag because it helps you to get off the line a little better. Comments or opinions?
Your search for lightweight flywheel returned 204 results.
Try using that red search button at the top of the page on something thats been covered to death.
You could have had your answer in a few minutes with some reading,instead of wasting your time and ours.
the only time you should use a light weight assembly in a honda is for road racing, whenyou are in the upper rpms all the time. for drag racing, always use steel. the extra inertia will keep the car from bogging as bad when you launch and in between shifts
allmotor1313
Dec 17, 2007 11:55 AM
Nealoc187
Apr 1, 2003 09:51 AM
