The ups and downs of a lightweight flywheel.
Old Dec 29, 2003 | 03:00 AM
KooK's Avatar
Mustang Sally
Default The ups and downs of a lightweight flywheel.
I'm just wondering, what are the pros vs. cons of a lightweight flywheel?
Thanks!
Old Dec 29, 2003 | 09:48 AM
Team 4's Avatar
Default Re: The ups and downs of a lightweight flywheel. (KooK)
It seems the heavier flywheels are easier to launch consistently, due to their "floating" effect (ie: they don't drop down as fast) . But the light weight ones rev up much faster, and free up hp.
Old Dec 29, 2003 | 10:14 AM
Nathan1234's Avatar
For straight road racing, get a light flywheel. For drag racing & normal driving, keep it heavy. You won't gain much top end in the 1/4 with a light flywheel, and you will likely end up running a tenth slower. A small 4 cylinder with a light flywheel has almost ZERO room between bogging off the line and burning up your tires and/or clutch when running the 1/4. You have more room with V8's (thanks to torque) but you will still probably be worse off as far as 60' time.
Old Dec 29, 2003 | 03:00 PM
raene's Avatar
I switched from a stock B16 clutch and flywheel to a lightened stock flywheel (fully rotationally balanced, 12.5 lbs) and an ACT HD clutch with stock disc. No change in 1/4 time, speed, or 60' time. I launch higher now, though.
Untouchable13
Honda Civic (2001 - 2005)
Jun 15, 2009 04:20 PM
integraboosted
Apr 22, 2006 05:50 PM
Edgar
37
Aug 15, 2005 12:04 AM
Mr. 1582
17
Sep 21, 2003 06:21 PM
Lo-Buck EF
Jan 7, 2002 02:16 PM
