Idle problems!!!
Old Jul 27, 2008 | 10:40 AM
DJP's Avatar
DJP
Default Idle problems!!!
Recently my car had the CEL on and there was a lot of fluxuation in the idle when stopping, or going around corners. After changing it, the idle fluxuation when going around corners and such went away....but for some reason anytime I turn on the headlights, heat, or if the radiator fan kicks in the idles take a serious drop...and it's only getting worse. Before changing the O2 sensor doing any of those things would have a similar effect, but a much smaller scale.
Since I've owned the car I've already had to change the alternator once and recently changed the battery after leaving my lights on a couple of times. I was also thinking that it could be due to some sort of carbon build up (since i would exeprience the fluxuation when sitting at stop lights in the middle of the day) so I tried cleaning the throttle body, and the intake manifold....no luck.
Any ideas on what could be?
Old Jul 27, 2008 | 10:53 AM
Former User's Avatar
Default Re: Idle problems!!! (DJP)
Is the CEL still ON?
Is the charge light ON?
You might want to clean the battery terminals and connectors, and also possibly charge the battery and have the alternator checked.
Old Jul 27, 2008 | 10:54 AM
iluvmy2000civicex's Avatar
Have you tried cleaning the IACV?
Old Jul 27, 2008 | 10:55 AM
DJP's Avatar
DJP
Default Re: Idle problems!!! (RonJ@HT)
Currently the CEL is not on anymore, as for the bettery terminals they're pretty clean, but i'll double check to make sure they're on nice and snug. As for checking the alternator, do most shops have equipement that can do it without completely removing from the car?
Old Jul 27, 2008 | 10:56 AM
I know AutoZone can do it without taking it off the car and its FREE!
Old Jul 27, 2008 | 10:57 AM
DJP's Avatar
DJP
Default Re: Idle problems!!! (iluvmy2000civicex)
That's a good suggestion. Totally forgot about that. I'll give that a try too. I tried changing the PCV the other day, but that didn't help. I figured I would change it only because it was the original one that came with the car and I didn't know when and if the previous owner has already changed it.
Old Jul 27, 2008 | 10:58 AM
In the U.S., AutoZone offers alternator checks free of charge, but I don't know if auto parts stores do the same in Canada.
Old Jul 27, 2008 | 11:01 AM
Well I would give the IACV a good cleaning and if that dont help go have your alternator checked for free.
Kindled Light
32
Mar 1, 2019 06:06 PM
dylokjai
Jul 28, 2008 12:12 PM
ex_ricer
Mar 20, 2008 05:25 PM
Probot
May 2, 2007 06:17 AM
justint
Jan 20, 2007 08:58 AM
