helicoil and turbo manifold?
Old Jul 27, 2008 | 08:00 AM
dartonh22's Avatar
Default helicoil and turbo manifold?
i stripped out my wastegate threads on the turbo manifold and i wanted to know if i can use i helicoil on the manifold or will it not work because of the heat and expansion.
i tried to retap it but it was to f'd up and i dont have room to go a size bigger because the larger bolt head will hit the side of the wastegate.
any help is much appreciated i really dont want to buy a new manifold.
Old Jul 27, 2008 | 09:09 AM
Adriano's Avatar
Default Re: helicoil and turbo manifold? (dartonh22)
What kind of manifold is it? Sometimes you can put a nut behind the flange.
Adriano
Old Jul 27, 2008 | 09:41 AM
dartonh22's Avatar
Default Re: helicoil and turbo manifold? (Adriano)
yeah, no i cant do that its a log style, i may just retap it a little bigger i just cant find a m9 bolt theyre all m10.
Old Jul 27, 2008 | 09:54 AM
pepsi in a can's Avatar
* B A N N E D *
M9 bolt is going to be hard to find locally..
Old Jul 27, 2008 | 10:28 AM
Adriano's Avatar
Default Re: helicoil and turbo manifold? (pepsi in a can)
Try using a allen head bolt one size bigger, even standard size. They also sell those "12 pt" hex head bolts that has small heads.
Adriano
Old Jul 27, 2008 | 04:30 PM
levelzero's Avatar
Helicoil should work, I know they are used on housings when turbos get rebuilt.
Old Jul 28, 2008 | 12:16 AM
nomrcy's Avatar
Why not weld up the hole and retap it again... ????
Old Jul 28, 2008 | 07:14 AM
dartonh22's Avatar
Default Re: helicoil and turbo manifold? (nomrcy)
well i just retapped it with some garbage tap from lowes and used a 3/8nc bolt and so far its good. thanks for all the responses.
Old Jul 28, 2008 | 06:52 PM
srmofo's Avatar
whats gonna happen when it fails?...You better weld a chain to it so you dont run it over when it pops off like a cork...lol...I would pay a professional to weld, drill , and retap it....I say professional because you have to heat cast to proper temps before welding
Old Jul 29, 2008 | 04:38 AM
dartonh22's Avatar
Default Re: helicoil and turbo manifold? (srmofo)
yeah, thats why i didnt weld it like the previous post suggested, but its not cast, its tubular, and if it "fails" the other bolt wil still hold it on it will just leak, not a big deal. i was just looking for a cheap solution, besides buying a new manifold, because if i were to get another one it would be a very expensive lovefab.
Old Jul 29, 2008 | 12:02 PM
srmofo's Avatar
I got ya, i thought you said it was a log style...loveFAb had there tub manis on sale for 650$ last month... i dunno if they still are?...I ended up goin with a p fab
theauthor17
Aug 8, 2008 11:47 AM
StolenTeg
Apr 19, 2008 11:11 AM
tegh22a
Aug 26, 2005 09:22 AM
B17aTrbo
Apr 12, 2004 09:39 PM
JDubya
Apr 8, 2004 08:01 AM
