Head to turbo manifold bolt back out?
I just noticed today that the top right nut on my head to turbo manifold has disappear? the stud is sitting there but somehow the nut has back out and fallen off.
So i went and grab another nut and tighten it back no big deal, as i got it hand tighten. I went to put a 12mm socket on it and give it a turn, snap it broke right off.
Now i didnt even get to tighten it, this is right after i hand tighten it and proceed to tighten it with a wrench.
As it break flush with the manifold, i would have to take the turbo manifold off and back the stud out with a vise grip probably but what i wanted to know is how does this back out?
I've seen manifold to turbo bolt back out but from the head to the turbo manifold, this is the first time i have this problem. It seem like the stud was already weaken that why when i put a new nut on it just snap?
Im running a topmount manifold with a t3/t4 turbo
Re: Head to turbo manifold bolt back out? (StolenTeg)
wrap and bolt or stud u dont want to back out with teflon tape.. its a non permanant locktite.. works great.
Re: Head to turbo manifold bolt back out? (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">wrap and bolt or stud u dont want to back out with teflon tape.. its a non permanant locktite.. works great. </TD></TR></TABLE>
Hmm that interesting, how does teflon tape help with keeping it from backing out? teflon is somewhat of a sealant.
I wasnt really **** that it back out but i was pissed when i put a new nut on and didnt even tighten it or anything and the stud snapped
i dunno how.. i guess it just stops it from moving. all i know is it works. 1 broken stud wont affect it.. i have one broke too..
erm, wont it just melt?
Re: Head to turbo manifold bolt back out? (blinx9900)
Just put a dab of blue loctite on the nut. Or use some split washers to keep tension on the nut from backing out. Or if you want to get really fancy, you can always safety wire all of the nuts together. Then they will never back out for sure.
hence the use of copper lock nuts like what i give out with all my kits
after using these we will never go back !!!!!!!!
Re: Head to turbo manifold bolt back out? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">after using these we will never go back !!!!!!!! </TD></TR></TABLE>
seriously, they work so well and it seems nobody knows about them... we stumbled on them working on german cars, one of the german OEMS uses them iirc...
cant the copper nuts only be used 1 time tho? they have that slit in them that gets compressed the first time you torque one down
Re: Head to turbo manifold bolt back out? (soHybridized)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soHybridized »</TD></TR><TR><TD CLASS="quote">cant the copper nuts only be used 1 time tho? they have that slit in them that gets compressed the first time you torque one down</TD></TR></TABLE>
Yes and no. If your lucky you can use them again. They do have a slit in the top of the nut that expands when the nut is threaded onto the stud. I forgot all about copper nuts. Those things work awsome. Also too, don't use anti-seize! They make a better one that has Nickel in the mix and its better suited for stainless studs and it has a greater heat range. I have installed a lot of turbo kits on the 350Z, and one of the kits comes with copper nuts. Well we used the regular anti-seize on the studs and wow what a mistake that was. Found out about the Nickel stuff and never had a problem since. I think the regular anti-seize has a heat range up to 1800 degrees F, where as the Nickel has a heat range up to 2800 degrees F. Don't quote me on the exact ranges. Hope this helps you out. Also too, the Nickel anti-seize is pretty pricey.
generally yeah but that goes for any locking nut
i've used them time and time again with great results
Re: Head to turbo manifold bolt back out? (TurboEK9Coupe)
my current set of copper nuts has come on and off about 3 times now, ive had to replace 2 of them cause they round off easily if your tool isent on them all the way... but yeah they still hold...
whiteblurr
01-24-2004 05:35 AM
