low oil pressure at idle??
Old Jul 27, 2008 | 07:12 AM
patrick4588's Avatar
Default low oil pressure at idle??
in the last couple days, my oil light comes on when the car is idling at 1000 or less, but goes away as soon as the rpms rise. obviously the oil pump is working since its driven by the crankshaft and the light goes off after the rpms rise. has anyone else had this issue? the oil level is fine btw. im wondering if i should swap to an s2000 filter for more oil pressure?
Modified by patrick4588 at 3:32 PM 7/27/2008
Old Jul 27, 2008 | 09:53 AM
slowcivic2k's Avatar
Default Re: low oil pressure at idle?? (patrick4588)
Um, the oil pump is driven directly by the crankshaft, not a belt...
Put a gauge on it and see what your pressures are, and if it doesn't have 5W30 oil in it, put it in. You should not be depending on a filter for pressure, that is what the extremely small clearances in the block/rods/head are for. By restricting the flow you will only cause more damage, in this case, by starving the bearings of oil.
Old Jul 27, 2008 | 11:35 AM
Default Re: low oil pressure at idle?? (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Um, the oil pump is driven directly by the crankshaft, not a belt... </TD></TR></TABLE>
yeah i know, i dont know why i put that. brain fart.
Put a gauge on it and see what your pressures are, and if it doesn't have 5W30 oil in it, put it in. You should not be depending on a filter for pressure, that is what the extremely small clearances in the block/rods/head are for. By restricting the flow you will only cause more damage, in this case, by starving the bearings of oil.</TD></TR></TABLE>
it has 5w30 in it and i have an oil pressure sender in my sandwich adapter, just havent plugged the gauge up (lazy i know). im not necessarily depending on a filter for pressure, i just know using the bigger filter it will bump up the pressure a couple psi. im wondering if my sensor is going bad, it is 14 years old.
Old Jul 27, 2008 | 12:02 PM
2ndchirp's Avatar
Get a volt meter and test the oil pressure sending unit it might be faulty or have some resistance
coryfenton
Jun 1, 2009 05:58 AM
xlee08
10
Apr 1, 2008 02:00 PM
Integritycaptain90
Dec 22, 2007 07:26 PM
hatchinprogress
Jan 7, 2006 07:48 AM
j954drgsr
Sep 19, 2005 12:55 PM
