hks piping with 60mm diamter (2.3") .. replacement??
Okay I have an HKS exhaust system I bought off someone for my other car. It's from the cat back but it didn't come with the mid pipe. I measured the inside diameter to be 2.36 inches which isn't standard size.
Should i just go for 2.25 inches or 2.5 inches for the replacement mid pipe?
thanks
thanks
i think thats 60mm piping. you can try find 2-3/8" pipe but that may be hard. 2.5 should be good. it will be a bit bigger and it will slip over so it might be easier to weld depending on what your welding with
