Pipes keep blowing off how to stop it.
Old Jun 5, 2008 | 07:08 PM
b16bri's Avatar
Default Pipes keep blowing off how to stop it.
hey guys, Last week I took some of my IC piping off and when we put it back on I made sure they were tight. But once i hit full boost they keep blowing off it's happend 3 times in the last 4 days. The pipe ends are beaded, What have you guys done to stop this ? The car didn't do this for the first 2 months but all of a sudden it dose. Do clamps go bad ? Also what size clamp do you guys use on the Coupler to TB connection ? I have 2.5 inch pipeing so I replaced the t-bolt clamp that was on there which was a 3" becuase i though maybe it was to big and stripped due to over tighting. So i baught a 2.5 and it's to small.
Old Jun 5, 2008 | 08:02 PM
ngogsr's Avatar
if you already have beaded ends w/ t-bolts and it still doesnt work, try wiggins? or make brackets
Old Jun 5, 2008 | 09:10 PM
inspyral's Avatar
You usually add .25" to the diameter of your piping to account for the thickness of the coupler when shopping for t-bolt clamps. For a 2.5" pipe connection, try a 2.75" t-bolt clamp.
Old Jun 5, 2008 | 11:56 PM
redboost10's Avatar
Default Re: (inspyral)
wipe everything down with carb clean, the pipe and the coupler...we were having the same problem, but not anymore. couplers were just dirty and "slippery"
Old Jun 6, 2008 | 04:36 AM
97_coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">You usually add .25" to the diameter of your piping to account for the thickness of the coupler when shopping for t-bolt clamps. For a 2.5" pipe connection, try a 2.75" t-bolt clamp.</TD></TR></TABLE>
What about the couplers, do you usually get them the same size as the IC pipe or do yo get them a little smaller or bigger than the pipe?
Old Jun 6, 2008 | 05:03 AM
siblues's Avatar
Default Re: (97_coupe)
Maybe you could use a hump coupler further down that intercooler pipe to take up some of the movement of the motor?
Old Jun 6, 2008 | 05:23 AM
chimmike's Avatar
Default Re: (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you could use a hump coupler further down that intercooler pipe to take up some of the movement of the motor?</TD></TR></TABLE>
this brings up a good point. There's no way you're to be blowing couplers off using tbolt clamps and beaded ends unless you're pushing 50psi or more. Seriously.
I'm curious if you're running any hump couplers? I am willing to bet motor movement is your issue, not clamps failing to hold.
Old Jun 6, 2008 | 10:15 AM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_coupe &raquo;</TD></TR><TR><TD CLASS="quote">
What about the couplers, do you usually get them the same size as the IC pipe or do yo get them a little smaller or bigger than the pipe?</TD></TR></TABLE>
Couplers are usually sold by the ID of the coupler, so you would purchase the coupler with an ID that matches the OD of your pipe. Read: by the same size as the pipe you want to connect.
Old Jun 6, 2008 | 12:22 PM
b16bri's Avatar
Hump hoses no i'm not running any just straight couplers. I will try a new clamp and wipeing down my couplers first due to the fact this has never happend before. If that dosent work i than will try a hump hose. as for boost it's at 20psi. So if i get a new clamp for over the TB get rid of the 3inch that was there and pick up a 2.75 ? . Thanks again guys
Old Jun 6, 2008 | 12:44 PM
91civicDXdude's Avatar
You could also clean the pipe ends with solvent and spray some sort of adhesive on them before you put the coupler on. I did this on accident on my old SOHC setup by spray painting the charge pipes an dputting couplers on it before it was completely dry... I had a hell of a time getting the couplers off when i took the kit off the car.
Old Jun 6, 2008 | 01:38 PM
VRD^don's Avatar
Default Re: (91civicDXdude)
hair spray the ends of the pipes and TB slip on the coupler .. hair will make that **** stick..
Old Jun 7, 2008 | 08:27 AM
b16bri's Avatar
Default Re: (VRD^don)
Alright thanks guys I'll let you know how i made out
Old Jun 7, 2008 | 08:36 AM
stockb18c's Avatar
ya hair spray or even paint would work
Old Jun 7, 2008 | 11:50 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (stockb18c)
i had the same problem, tried everything, so finally i had them all welded together, only couplers i have are on the tb, turbo outlet, and ic... best move i ever made as there is no chance in hell they will ever blow off again. on the downside to get the tb-ic pipe in, i have to jack the car up and feed it through all of the twists and turns
Old Jun 7, 2008 | 10:14 PM
ptftw's Avatar
Default Re: (oneludesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem, tried everything, so finally i had them all welded together, only couplers i have are on the tb, turbo outlet, and ic... best move i ever made as there is no chance in hell they will ever blow off again. on the downside to get the tb-ic pipe in, i have to jack the car up and feed it through all of the twists and turns </TD></TR></TABLE>
haha i guess thats best way to go.
Old Jun 7, 2008 | 11:22 PM
b16bri's Avatar
Default Re: (ptftw)
lol Ya i guess so altho it's keeps blowing off at the TB lol
Old Jun 8, 2008 | 05:09 AM
chimmike's Avatar
Default Re: (b16bri)
Like I said dude. You need hump hoses.
Old Jun 9, 2008 | 08:31 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16bri &raquo;</TD></TR><TR><TD CLASS="quote">lol Ya i guess so altho it's keeps blowing off at the TB lol</TD></TR></TABLE>
the way mine is done, when the pipe is installed without couplers, it rests about 1/2" from the tb and 1/2" from the ic. so what i have to do is put the coupler on the tb and ic, and fold it over inside out, install the pipe, and then fold the coupler back over the pipe. there is not enough physical clearance for a blow out LOL
accordfreak
Welding / Fabrication
Jul 27, 2008 09:58 PM
the.hamburglar
Jun 26, 2005 11:56 PM
5thgen
Feb 25, 2004 09:15 PM
Jared
Jun 24, 2003 07:48 PM
blufke
Oct 25, 2002 03:31 PM
