skunk2 pro 2 on a stock b18cR block and ecu
hey guys im planning on rebuilding my b18cR head with the complete skunk2 pro series stage 2 (cams, gears, retainers, valves, springs etc.) I was wondering if the motor would run on a stock block and stock ecu? and if it does run would this do harm to the motor in anyway.
it won't *harm* it but without a tune you also won't be making the most power with that setup
a good tune is just as good as, if not more important, than all of the parts of that setup
yeah your not going to get the most outta those cams unless you have it tuned,switch over to obd-1 id you havent already and get some type of ems and get it dyno tuned.
StreetLethaleg6
17
Aug 13, 2010 11:04 AM
