skunk2 pro 2 on a stock b18cR block and ecu
hey guys im planning on rebuilding my b18cR head with the complete skunk2 pro series stage 2 (cams, gears, retainers, valves, springs etc.) I was wondering if the motor would run on a stock block and stock ecu? and if it does run would this do harm to the motor in anyway.
Re: skunk2 pro 2 on a stock b18cR block and ecu (d0odle)
it won't *harm* it but without a tune you also won't be making the most power with that setup a good tune is just as good as, if not more important, than all of the parts of that setup
Re: skunk2 pro 2 on a stock b18cR block and ecu (tamadrumr88)
yeah your not going to get the most outta those cams unless you have it tuned,switch over to obd-1 id you havent already and get some type of ems and get it dyno tuned.
