no spark....
Old Jul 26, 2008 | 01:44 PM
wu tang's Avatar
Default no spark....
im going to try out a new main relay not sure if that's going to do anything. I've done 2 differant dizzys and 2 ecus. Any ideas?
Old Jul 26, 2008 | 01:47 PM
wu tang's Avatar
Default Re: no spark.... (wu tang)
also..are 88-2000 main relays the same?
Former User's Avatar
The main relay controls fuel not spark. Check the coil and igniter in the distributor. Also make sure there aren't any blown fuses and that the distributor connector is getting battery voltage.
Old Jul 26, 2008 | 01:51 PM
wu tang's Avatar
Default Re: no spark.... (RonJ@HT)
is this the black/yellow wire? if so it is getting power. Someone told me the main relay does control some spark to. but i was alittle confused on that part. also the dizzy i have works i know that for a fact. i took it out of a friends running car
Old Jul 26, 2008 | 01:56 PM
The main relay controls the fuel pump and fuel injectors. Is the fuel pump priming?
Check the critical ground wire on the thermostat housing -- loose, disconnected, corroded?
Old Jul 26, 2008 | 02:00 PM
wu tang's Avatar
fuel is priming and grounds are good to go. Im wondering if im missing something down under the dash? but i dunno im quite confused though
Old Jul 26, 2008 | 02:02 PM
Is it an 88 Civic? Is the CEL ON?
Old Jul 26, 2008 | 02:10 PM
wu tang's Avatar
96 civic hb
Old Jul 26, 2008 | 02:16 PM
If you have power to the distributor, no CEL codes (e.g., distributor sensors), and grounds are good, then focus on the coil and igniter and their wires and connectors.
Have you also inspected the plugs, wires, cap and rotor?
Old Jul 26, 2008 | 02:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang &raquo;</TD></TR><TR><TD CLASS="quote">Im wondering if im missing something down under the dash?</TD></TR></TABLE>
Check whether fuse 47 (hood) or fuse 31 (dash) is blown.
Are you able to retrieve any CEL codes?
Old Jul 26, 2008 | 02:37 PM
Results from tests in the diagram should be informative, particularly those with the YEL/GRN wire.
Old Jul 26, 2008 | 03:26 PM
wu tang's Avatar
perfect thank you. Also i'm in idot the fuel pump is not turning on. lol so..where is that dang main relay at?
Old Jul 26, 2008 | 03:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang &raquo;</TD></TR><TR><TD CLASS="quote">where is that dang main relay at?</TD></TR></TABLE>
Pull out the glove box and it is on the right.
Old Jul 26, 2008 | 03:47 PM
mattscivic1's Avatar
have fun its all the way under your dash. i might be wrong but it should be on the left hand side.
Old Jul 26, 2008 | 04:00 PM
wu tang's Avatar
good thing i like to have fun then. Are 88-00 main relays the same?
Old Jul 26, 2008 | 04:32 PM
Now that you know that you also don't have fuel, you may want to check the wire between the MAP sensor and ECU at some point.
Old Jul 26, 2008 | 04:36 PM
Default Re: no spark.... (mattscivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattscivic1 &raquo;</TD></TR><TR><TD CLASS="quote">have fun its all the way under your dash. i might be wrong but it should be on the left hand side.</TD></TR></TABLE>
Old Jul 26, 2008 | 06:11 PM
wu tang's Avatar
jsut went tot he car again. Now i have fuel lol. my codes are 20 and 14. I'm not worryed about the 14. car still would not start. no spark still
Old Jul 26, 2008 | 06:21 PM
Try the electrical troubleshooting of the distributor shown in the diagram of my earlier post.
Old Jul 26, 2008 | 07:11 PM
wu tang's Avatar
I will go back to the car tomorrow. Thank you for your help and i shall let you know the results tomorrow.
Old Jul 27, 2008 | 09:53 PM
wu tang's Avatar
sunday night....new status. The only code im throwing now is a 41. still no spark
Old Jul 27, 2008 | 10:09 PM
Yeah, a problem with the primary O2 sensor/heater (code 41) isn't going to lead to a no-spark situation.
Old Jul 28, 2008 | 08:00 AM
wu tang's Avatar
yup. but everything is good, fuze/grounds/ecu/dizzy. its just weird
Old Jul 28, 2008 | 07:31 PM
worlds-slowest-EG's Avatar
use a little di-electric grease on the ignitor on the front and back it solved my problem i had no spark and no cel's tried 4 ignitors and 3 coils but all it took was a little lube
Old Jul 29, 2008 | 05:06 PM
wu tang's Avatar
Default Re: no spark.... (worlds-slowest-EG)
shes alive!!! thank you
dudesmccool
11
Dec 30, 2015 01:55 PM
panda teggy
11
Jul 6, 2011 01:18 PM
Coltmorris
Sep 11, 2009 12:51 PM
90turbointegra
Sep 2, 2009 03:41 PM
chicows18
21
Jan 16, 2008 09:30 AM
