Radiator fan doesnt work
Old Jul 26, 2008 | 01:28 PM
esean93's Avatar
Default Radiator fan doesnt work
my radiator fan doesnt either nd i think its an electrical problem.i tested the cooling fan relay fuse nd its not getting any circuit(used a 5amp fuse instead of a 7.5amp fuse ran the car nd the fuse didnt melt).so if the cooling fan relay fuse is not getting circuit then its obviously not the cooling fan relay so its has to be radiator fan switch rite?does anyone kno where its at?
p.s the engine temperature guage isnt working but that wouldnt be a problem rite?
Old Jul 26, 2008 | 01:30 PM
z6hatchboy's Avatar
I would start with the engine temp sensor, that could be the problem, if not that then go to the fan switch. If you need to just straight wire the fan to a switch for now.
Old Jul 26, 2008 | 01:36 PM
Former User's Avatar
Default Re: Radiator fan doesnt work (esean93)
You can test whether the coolant temperature switch in the thermostat housing is bad by uncoupling the 2P connector and putting a jumper wire across the two terminals of the connector. If the switch is bad, the radiator fan will run continuously when the ignition key is turned to ON.
Old Jul 27, 2008 | 10:09 AM
esean93's Avatar
Default Re: Radiator fan doesnt work (RonJ@HT)
thnx dude but r u talkin bout the coolant temperature switch(beside the lower radiator hose) or the coolant temperature sending switch(rite under the dizzy)?
Old Jul 27, 2008 | 10:15 AM
I am referring to the coolant temperature switch (2P connector) located on the thermostat housing.
The sending unit for the temperature gauge has a 1P connector and is located beneath and forward of the distributor.
Right next to the sending unit is the coolant temperature sensor (I think 2P connector) that talks to the ECU.
Old Jul 27, 2008 | 10:25 AM
esean93's Avatar
ok ill check that out tonight nd let u kno.
Old Jul 28, 2008 | 10:54 AM
esean93's Avatar
i jumped the eng.cool.tem.swtch nd it worked.i also ran the car nd noticed that the lower radiator hose was ice cold so it doesnt neccarily hav to be the ECT switch rite?could the fan not work cuz of a bad thermostat?
Old Jul 28, 2008 | 11:19 AM
Yeah, first make sure the thermostat is not stuck closed.
Old Jul 29, 2008 | 01:49 PM
esean93's Avatar
wait im confused.which one is the thermostat housing?the housing where the upper rad hose goes or where the lower rad hose goes?the ect switch is on the housing where the lower rad hose goes.
Old Jul 29, 2008 | 02:40 PM
Default Re: (esean93)
The thermostat is located in the housing where the ECT switch is located, not where the ECT sensor or sending unit is located.
Old Jul 29, 2008 | 03:46 PM
nekoabandoned's Avatar
Default Re: (RonJ@HT)
hard wire ftw
Old Jul 29, 2008 | 05:33 PM
esean93's Avatar
o ok just makin sure cuz thermostats usually where the upper rad hose goes.thnx btw how do i give props nd stuff to ppl?
EK9JSPEC
Aug 27, 2012 09:11 PM
Sir^Ducer
Aug 1, 2006 02:15 AM
PearlBlueType-S
May 1, 2006 11:58 AM
iNetForce
Mar 3, 2006 03:48 PM
harveyy
17
Mar 1, 2006 04:32 AM
