Radiator fan not turning on
Old 08-27-2012, 08:52 PM
EK9JSPEC's Avatar
Default Radiator fan not turning on
What control's the radiator fan to come on? Seems like my radiator fan is not turning on making my temp gauge rise then fall back down,just did my coolant flush,thermostat,coolant temp switch also
Old 08-27-2012, 09:06 PM
ANNiHiLATORS's Avatar
Default Re: Radiator fan not turning on
Fan switch sensor.. On thermostat housing
Old 08-27-2012, 09:11 PM
Ryan Lwin's Avatar
First of all, check for the fuse in the under-hood fusebox.
If that's ok, unplug the temp switch right above where the thermostat and bottom radiator hose meet. Then with the key at ON position (without starting the engine) short the two pins from that relay using anything conductive. Screw driver or wire. See if the fan turns on.
If that doesn't work, check for the voltage across the lead where the fan is connected while the relay is still being shorted.
redbull99
08-27-2015 10:19 AM
nfiniti9
06-09-2012 02:14 PM
JH4DB858
01-10-2012 07:32 PM
jkalex05
08-22-2009 07:02 AM
esean93
11
07-29-2008 05:33 PM
Quick Reply: Radiator fan not turning on
