Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Need Help on DTC issue
Old Jul 26, 2008 | 10:47 AM
discodave_uk's Avatar
Default Need Help on DTC issue
Ok, I have a UK accord (or TSX), I have a issue were my ABS/VSC light remains on, It did go out for a while and all worked fine.
This light came on not long after I jet washed along the tops of the wings and edge along by the wipers. I was carefull not to get water anywere near the engine or wiring.
The ABS/VSC light will only go out if I unplug the brake fluid level connector, but soon returns. I have checked the switch operation and it all seems fine.
I have also used a OBDII reader to try to retrive the DTC from the ECU, but looking at the circuit diagram I see they are stored in the ABS/VSA unit. Am I right in thinking that with a standard ODBII reader I will not be able to access the ABS/VSA faults codes.
any advice is welcome, shame my first post here is asking for help. Been a member of THAOC for a while and used to belong to CCUK, so find forums a very handy tool
Old Jul 26, 2008 | 12:31 PM
MSchu's Avatar
My Name is Nobody
Default Re: Need Help on DTC issue (discodave_uk)
generally the abs signal/sign is either an indication of low brake fluid, the traction control being turned off manually, a bad abs sensor, or perhaps even low brake pad material. Have you checked those obvious items?
Another thing that will make the abs light come on is a bad abs circuit fuse
Old Jul 26, 2008 | 01:55 PM
Default Re: Need Help on DTC issue (MSchu)
Would a faulty ABS sensor not registered as a DTC, the brake fluid is fine and so is the level sensor. I really do need to know how to access the ABS DTC fault codes.
I have also checked the brake switch and all connections to the ABS sensors, So still unsure what it is
Old Jul 26, 2008 | 04:36 PM
phootbag's Avatar
The dealership should be able to troubleshoot your vehicle efficiently. They have access to the proper scan tool and DTC troubleshooting material.
b18LS
Oct 25, 2008 09:55 AM
Vagabund07
Oct 7, 2007 06:06 PM
DC231_01
Jun 26, 2006 08:37 PM
FLATOUTRACING
Dec 11, 2005 03:06 PM
jdmlude_dude
Mar 16, 2004 06:01 PM
