my DAs fans wont turn on, not an electrical guy, 175 cash to whoever will come fix that problem...
i live in fredericksburg, need this done and dont want a shop bill. 540 907 7543
540 548 4243
540 548 4243
dude dont wasnt your money...it could be a fuse..check the fuse under the hood for the fan...if the metal inside isnt a full arc than its blown....or maybe the fan needs to be replaved...a couple bolts and a clip to unplug and out come the fan...that simple
I requested a short story for a title.
hmm well i guess you could rig up some wiring and connect it straight to the battery for a few seconds to see if the fan spins then, also i think there might be a relay in there somewhere like right around where the fan is that controls the cooling fan.
and what do you mean by "you just checked the thermostat", did you let it warm up? or did you remove it and test it?
i replaced it, bt as of ryte now my fans still dont turn on but my car isnt running hot, weird or are the fans not supposed to turn on until the car actually begins to run hot ?
Eglifestyle
10
Mar 23, 2008 12:08 PM
