Old Mar 25, 2015, 10:05 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
97 accord ignition coil
Old Jul 25, 2008 | 10:11 AM
chrissbee77's Avatar
Default 97 accord ignition coil
Hi i have a 1997 accord v6 how do you remove the ignition coil? any pics would greatly help as i am simi retarded when it comes to cars thank you
Old Jul 25, 2008 | 01:19 PM
corchado85's Avatar
Default Re: 97 accord ignition coil (chrissbee77)
on the V6 is the coil ignition inside the distributer or is there a spark plug that connects to the coil ignition??????????
Old Jul 25, 2008 | 02:55 PM
Farrukh's Avatar
if its related to the f22b then its on the inside because i did my spark plug wires and theres nothing else on the distributor
Old Aug 9, 2008 | 08:36 PM
mouab18c1's Avatar
Default Re: (Farrukh)
the ignition coil is inside the distributor....take the cap dizzy cap off and then you'll have to remove the rotor...once the rotor comes off the cover should come right off and you should see the coil...i believe its just two screws.....and yeah all ignition coils are inside the distributor...
Old Aug 10, 2008 | 07:30 AM
GhostAccord's Avatar
Default Re: (mouab18c1)
The ignition coil on the 97 Accord V6 is external. There should be a center coil wire attached to your distributor cap. That will lead you to your coil. It should be mounted just to the right of the distributor near the top of the engine. There are 3 bolts that mount it onto the bracket. Be careful when removing the bolts as there are spacers between the coil and the bracket that you don't want to loose. Sorry I don't have any pics right now if I find one i'll post it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mouab18c1 &raquo;</TD></TR><TR><TD CLASS="quote">the ignition coil is inside the distributor.....
....and yeah all ignition coils are inside the distributor...</TD></TR></TABLE>
That's kind of a broad and incorrect statement. Not all coils are internal.
Modified by GhostAccord at 12:37 PM 8/10/2008
Old Aug 10, 2008 | 07:41 AM
mouab18c1's Avatar
Default Re: (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">The ignition coil on the 97 Accord V6 is external. There should be a center coil wire attached to your distributor cap. That will lead you to your coil. It should be mounted just to the right of the distributor near the top of the engine. There are 3 bolts that mount it onto the bracket. Be careful when removing the bolts as there are spacers between the coil and the bracket that you don't want to loose. Sorry I don't have any pics right now if I find one i'll post it.
well my bad..all my experiences....never seen one on the outside.....
Modified by GhostAccord at 12:37 PM 8/10/2008</TD></TR></TABLE>
NeMeSiS 171
Feb 19, 2013 09:44 AM
CaliforniaDad
Mar 18, 2012 03:49 PM
kelvinchau25
Aug 29, 2006 07:05 PM
Aquafina
Apr 19, 2006 04:52 AM
h22aLSD
Oct 10, 2003 07:48 AM
