Fresh motor, first start/drive/break-in, car bogs really bad, idle horrible
Old Jul 24, 2008 | 04:08 AM
aleks77's Avatar
Default Fresh motor, first start/drive/break-in, car bogs really bad, idle horrible
hey guys i got a 1991 accord, fresh built motor, forged rods/pistons, built head, etc.etc. I can give more specs if needed?
I started the car up and right from the start it idled really bad, like jump from 1200 to 800 then to 1000 then to 600 and then die.
When i took it for a drive to break it in, things got worse. If i floor it WOT sometimes it actually drops in RPM and than kinda accelerates, but really really shitty....its just bogging like crazy. Altho i was able to get a couple 1st gear WOT to 5000 rpm, and it felt great, but as soon as you hit 2nd gear just bogs and sounds like ****.
Any suggestions are really really appreciated!
Old Jul 24, 2008 | 10:34 AM
tequilakid's Avatar
What are you using for tuning? What basemap?
Old Jul 24, 2008 | 07:08 PM
aleks77's Avatar
no tuning, everything is stock, stock ecu, stock cam, stock injectors, stock exhaust/intake, etc.
Old Jul 24, 2008 | 07:21 PM
racerxh00's Avatar
Default Re: (aleks77)
sound slike a compression problem. but first check your basics. vacuum leaks, spark (and timing, you might be like 90 out) fuel and air.
Old Jul 24, 2008 | 09:29 PM
ITR-EKcoupe's Avatar
Default Re: Fresh motor, first start/drive/break-in, car bogs really bad, idle horrible (aleks77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks77 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i got a 1991 accord, fresh built motor, forged rods/pistons, built head, etc.etc. I can give more specs if needed?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks77 &raquo;</TD></TR><TR><TD CLASS="quote">no tuning, everything is stock, stock ecu, stock cam, stock injectors, stock exhaust/intake, etc.</TD></TR></TABLE>
head is built but stock..?? is your CR of your pistons the same as stock?? if not im pretty sure youd need to retune for that aswell.. correct me if im wrong.
Old Jul 25, 2008 | 12:11 PM
B18CUL8R's Avatar
do some trouble shooting
Old Jul 25, 2008 | 07:11 PM
aleks77's Avatar
ok car runs a LOT better now
what i did was attach the stock o2 sensor to the stock harness, but kept my wideband in the header, and i also attached the map sensor vacuum plug closer to the throttle body.
This seems to have solved the problem, car runs good, idles still funny, but gettin a pro mechanic to take a look at it tommorow. Will post back with results, doing valve adjustment too, its starting to tick, the car has been running/driven for 40-50 mins without adjustin valves, hope its not too late...
machine4321
Dec 4, 2003 06:34 PM
team2n1hatch
Sep 20, 2003 08:33 PM
2faz2paz
Jan 17, 2003 10:34 AM
B00ST2nR
Sep 5, 2002 03:37 PM
Yyz
Jan 27, 2002 09:15 PM
