Estimate Input and Ideas (99 EX Rear panel Damage)
Old Jul 23, 2008 | 10:22 PM
Xscort's Avatar
Default Estimate Input and Ideas (99 EX Rear panel Damage)
So, I bought this 99 EX for $2900 w/111k. The hood paint has worn off for some reason and the guy had a lil fender bender. The car is not insured, thus I'm not driving it at the moment, but how much do you think the repair on this side dent will cost?? I already removed the driver rear interior panels and seats for easier/better access.
I'm no body person, so I doubt I could tackle this myself.
Modified by Xscort at 2:28 AM 7/24/2008
Old Jul 24, 2008 | 02:17 PM
tattoo'd's Avatar
Default Re: Estimate Input and Ideas (Xscort)
best way to see how much it costs is to find a body shop that will come out to your place for an estimate. they are out there. otherwise drive a few miles in it and take it to get an estimate.
Old Jul 24, 2008 | 04:30 PM
Xscort's Avatar
yes i figured i could do that, i dont think u read that the car is uninsured, and i dont take chances to just drive my car to get an estimate. that's why asked, maybe someone had some similar damage and could chime in, but thanks for the input.
Old Jul 25, 2008 | 02:45 AM
mztykal's Avatar
Default Re: (Xscort)
New quarter panel = 1k.
Old Jul 25, 2008 | 08:19 AM
IMPATIENT's Avatar
Default Re: (mztykal)
definitely would reccomend a new quarter panel. you can almost guarantee at least a minimum of 800 if they dont blend into the door. But that door looks like it needs some work as well so your looking well above 1k.average cost of a quarter panel replacement in our shop for a civic/integra is around 1200 since 99 percent of the time we will blend into the door and other surrounding panels if neccassary, other cars are more expensive since sometimes aftermarket panels are not available and you have to get them from the dealer which is very costly. Luckily for you just about every aftermarket company makes quarter panels for civics.
it doesnt ABSOLUTELY need a new quarter panel, that panel can be worked out and bodywork can be done. BUT a new panel is definitely the better way to go. doing a ton of bodywork and using lots of filler makes the panel weaker and more prone to paint problems later on. if it was my car, a new panel would be going on. But if you know someone good with a hammer and dolly, and can manipulate filler to come out nice than you may be able to save yourself some money, but in the long run its definitely a better idea to replace the panel.
Old Jul 25, 2008 | 05:16 PM
Xscort's Avatar
Default Re: (IMPATIENT)
Preciate the more clear input. To keep the car cost better, I believe I'll just buy the rear panel. The frame part shouldn't be so much damage, therefore I'll just get the body panel and let the shop or whoever work the frame.
I'm looking not spend more than a $1100 even with this part. Hopefully?!?!?!?
04646-S02-A12ZZ 6 PANEL SET, L. RR. (OUTER) USA 1 $ 772.03 $ 569.76
is this the driver side?
so is this the right part from hondapartsdeals.com???
Old Jul 27, 2008 | 11:54 AM
Eyger's Avatar
There are exploded diagrams on hondapartscheap.com you can check to see if the part numbers match the ones you have.
Old Jul 29, 2008 | 10:04 AM
StockDC2's Avatar
Default Re: (Eyger)
I'm pretty sure that after paint and everything, you're going to be looking at a lot more than $1100.
Old Jul 29, 2008 | 04:03 PM
dispocrx's Avatar
i say at least 1500 for the door and quarter being repaired, then blend on the decklid and bumper...but if you want it done right then thats the route you need to go....and thats a real low price for that so you could be looking at more!
I repaired and painted a frontend on a legend for 3200$ and every penny was accounted for...it depends alot on the shop writing the estimate...thats why insurance companies tell you to get 3 estimates from dif shops when you get in a wreck..
Old Jul 31, 2008 | 08:49 PM
Xscort's Avatar
well when i do order the panel, i'ma see if i can get it ordered already painted using the paint code and when put it, i guess only the lining portions will have to be blended and painted??
Old Aug 1, 2008 | 03:43 AM
IMPATIENT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xscort &raquo;</TD></TR><TR><TD CLASS="quote">well when i do order the panel, i'ma see if i can get it ordered already painted using the paint code and when put it, i guess only the lining portions will have to be blended and painted??</TD></TR></TABLE>
NO. please do not order a quarter panel painted, i dont even believe they come painted. Welding needs to be done to the panel, bodywork needs to be done to the panel to smooth out the weld spots that the shop will have to do on the rear pillars that they cut the panel off on, and near the rear decklid and such.
Nave43
Honda CR-V & Element
Sep 6, 2018 04:13 PM
stoves
Paint and Body
May 30, 2016 12:22 AM
pastord
Nov 26, 2014 02:57 PM
Sleek98
Jan 14, 2005 10:28 AM
