Horn problem
Old Jul 21, 2002 | 07:44 AM
CivicHB-Si's Avatar
Default Horn problem
The horn on my 93 civic hatchback seems to have a problem. It will work half the times i try to use it, but the other half of the times i try to use it it wont work. I can hear that clicking sound when i press the button, but thats all, no horn sound. Does anyone no what it might be? maybe a loose connection somewhere? Thanks for any help!
Old Jul 21, 2002 | 08:09 AM
fOmaNPu's Avatar
Default Re: Horn problem (CivicHB-Si)
Mine does the same exact thing. I was told it was flooded or something, I haven't really tried to fix it yet though. In plce of my horn I stick my head out of the sunroof and scream a stream of profanity...
Old Jul 21, 2002 | 08:42 AM
shermanyang's Avatar
replace your horn. it's not hard...it's just like replacing a speaker...that's almost what it basically is.
Old Jul 21, 2002 | 08:51 AM
CivicHB-Si's Avatar
Default Re: Horn problem (shermanyang)
thats what i'll probably have to do, but it might be the wiring, anyone know where the wires run so i can check them out??
Old Jul 21, 2002 | 09:02 AM
just check it with a voltage thingy...to see if any power is running to it when the horn is pressed. most likely it's not the wiring. the wires are bunched up so i'm thinking you wouldn't want to go through unwrapping all that stuff. good luck man...if you lived in st.paul i'd give you a few horns since i've got like 10 of em.
94 IntegraLS
Sep 17, 2007 05:29 PM
bigslimdog
Nov 16, 2004 03:55 PM
Fly1865
Jun 17, 2004 01:00 PM
OnEsIcKLs
Apr 27, 2004 04:31 PM
bossman032
Nov 14, 2003 03:10 PM
