how much horsepower can a stock 97 prelude auto trans hold?
Old Jul 23, 2008 | 11:36 AM
turboorsupercharger's Avatar
Default how much horsepower can a stock 97 prelude auto trans hold?
i have a 97 prelude with the 4 speed auto trans in it with the sport mode. I need to know how much horsepower the trans can hold. does anybody know?
Old Jul 23, 2008 | 11:44 AM
ESP.net's Avatar
Default Re: how much horsepower can a stock 97 prelude auto trans hold? (turboorsupercharger)
Honda/Acura Automatic Transmissions have hard time holding up with a lil more additonal power let alone a lot of power. They just aren't strong enough. Not a lot of Rebuilders of Transmission Honda Performance oriented places will touch the Autos for a lot of power builds...
I would imagine 250-300 hp would be pushing it... my 2 cents...
Old Jul 23, 2008 | 11:45 AM
vinuneuro's Avatar
The 5g auto transmissions fail at an exceptionally high rate even with a stock engine. I'd leave everything alone and hope for the best.
Old Jul 23, 2008 | 11:47 AM
DR1V3N's Avatar
For any decently high hp output you should consider upgrading to a manual tranny. I know, I am sure you have already heard this
Old Jul 23, 2008 | 11:54 AM
ok yeah i want to put on a t3/t4 turbo that will increase another 100 hp and 8 psi and i'm affraid if i put it on ill blow my tranny. if i put the turbo on my car will put out a little over 300hp
Old Jul 23, 2008 | 12:00 PM
Default Re: how much horsepower can a stock 97 prelude auto trans hold? (vinuneuro)
so if i get a 5 speed manual prelude trans what do you guy think that will hold?
Old Jul 23, 2008 | 05:57 PM
93PreludeVTEC's Avatar
with the right clutch/flywheel set-up and other random tranny internals the sky is the limit lol
Old Jul 23, 2008 | 06:05 PM
ESP.net's Avatar
Default Re: how much horsepower can a stock 97 prelude auto trans hold? (93PreludeVTEC)
LSD with a manual trans is a must with high HP... a good clutch combo meanin spendy is a must as well...
Right around 500-600 whp is where I see stock H trannys take a dump with non LSD
A buddy went through 4 or so H non LSD tranny's 600 whp mark, even a built trans aftermarket gears non LSD, put's in a stock H trans with LSD sure enough hasn't broken yet haha
Old Jul 23, 2008 | 06:14 PM
ProjectBB6's Avatar
Default Re: how much horsepower can a stock 97 prelude auto trans hold? (ESP.net)
get a trans cooler for that auto and you will be fine. Matter a fact we have a 400whp auto prelude on our forums. Your going to have to search tho. I believe the trans is built tho.
Old Jul 24, 2008 | 09:18 PM
Default Re: how much horsepower can a stock 97 prelude auto trans hold? (ProjectBB6)
so you think a stock auto trans can hold up to 600 whp?
Old Jul 24, 2008 | 09:20 PM
ProjectBB6's Avatar
rofl... No
Old Jul 24, 2008 | 09:25 PM
JTCdudeman's Avatar
Master H Technician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboorsupercharger &raquo;</TD></TR><TR><TD CLASS="quote">so you think a stock auto trans can hold up to 600 whp? </TD></TR></TABLE>
the truthful answer is about 175 hp and it comes with 200 stock.. You do the math. Also search SS tranny failure.
Old Jul 24, 2008 | 09:43 PM
Default Re: how much horsepower can a stock 97 prelude auto trans hold? (JTCdudeman)
If that was the case then i would have blowen my tranny a while ago because i got my car putting out around 240
Old Jul 24, 2008 | 10:16 PM
JTCdudeman's Avatar
Master H Technician
its only a matter of time.
Old Jul 25, 2008 | 09:09 AM
ESP.net's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">LSD with a manual trans is a must with high HP... a good clutch combo meanin spendy is a must as well...
Old Jul 25, 2008 | 09:57 AM
Hawkze_2.3's Avatar
NO, HAVE YOU BEEN READING ANY OF THE RESPONSES???
They barely hold stock HP levels You have a LOT more research to do before you put any turbo on your car.
kenneth4g4d
Aug 6, 2014 10:51 PM
turboorsupercharger
Jul 26, 2008 02:41 PM
jopjop
Apr 4, 2005 04:57 AM
MNsnowdaboy
May 16, 2004 07:20 PM
hondanacura4life
May 21, 2002 10:08 PM
